Winterizing bike....
- oredigger
07 Nov 2013 19:01 #612375
by oredigger
1980 KZ650-E1 LTD
Winterizing bike.... was created by oredigger
So i always read about clearing the carbs come winter time when the bike is gonna sit for a while...but what else? I am in the process of rebuilding my carbs along wit some other work and because of school I probably wont have the bike ready to run until january. Do i need to worry about amything else?
1980 KZ650-E1 LTD
- Beaner242
- Thank you received: 16
07 Nov 2013 19:20 #612382
by Beaner242
1982 KZ1000K LTD Chopper
Replied by Beaner242 on topic Winterizing bike....
I don't but a lot of people will raise the bike so the tires are off the ground. The fuel can go bad unless you also run the tank dry or put some Stabil in it. Just shut the fuel off and let the bike run until it dies. You should actually do this after every ride if you own a 2 stroke. Keeps the oil from gelling in carb between rides.
- Thank you received: 2829
07 Nov 2013 19:34 #612385
by 650ed
Replied by 650ed on topic Winterizing bike....
Draining or running the carbs dry is good, but DO NOT run the fuel tank dry or empty it. If you do condensation will form in the tank and cause it to rust. Gasoline will not rust the tank. Fill the tank as full as possible, and if you don't plan the run the engine every week or two add the appropriate amount of Stabil or SeaFoam to keep the gas from going bad. Ed
The following user(s) said Thank You: oredigger
- Beaner242
07 Nov 2013 19:41 #612391
by Beaner242
And there ya go. Someone that knows what they are doing. Lol
- oredigger
08 Nov 2013 13:01 #612516
by oredigger
1980 KZ650-E1 LTD
Replied by oredigger on topic Winterizing bike....
Lol that's why were all here beaner...
Ed do I need to just put one done of SeaFoam in for the entire winter? Or should I add more periodically? I am guessing the former but wanna be sure...
1980 KZ650-E1 LTD
- rstnick
- Thank you received: 377
08 Nov 2013 13:39 - 08 Nov 2013 13:44 #612523
by rstnick
Rob
CANADA
1978 KZ650 C2, 130K kms, Delkevic ex, EI, CVK32, PMC easy clutch, ATK fork brace, steering damper, braced swingarm, 18" Z1R front wheel.
2000 ZRX1100
2011 Ninja 250R
2005 z750s
Replied by rstnick on topic Winterizing bike....
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R
2005 z750s
Last edit: 08 Nov 2013 13:44 by rstnick.
