KZ keys
- geerbangr
KZ keys
18 Oct 2013 01:13
So I have 2 keys for Oscar. 1 key works ignition switch. 1 key works gas tank. Keyhole for seat has been modified with a screwdriver by PO. Did the KZ's have 1 key that fit entire bike ? If so how do I go about correcting the issues and getting 1 key to fit the entire bike ?
1978 KZ 1000
I go by Jason
I go by Jason
- GPzEric
Re: KZ keys
18 Oct 2013 01:16
I would take the working ignition key, and take it, and the other locks to a locksmith, and have him re-key the locks to match the ignition key - my local locksmith charged me $20.00 the last time I did that.
My wife asked me if I still loved her - I said "Honey, I love you more than new carburetor boots ! "
1982 KZ1100B2 (GPz)
1982 KZ750R1 (GPz)
(2) 1981 KZ550D1 (GPz) 1 mint, 1 under construction
1983 GS1100E
1982 KZ1100B2 (GPz)
1982 KZ750R1 (GPz)
1983 GS1100E
- geerbangr
Re: KZ keys
18 Oct 2013 01:44
Thanks for the reply Eric. Can a kaw shop do that for me or just a locksmith ?
1978 KZ 1000
I go by Jason
I go by Jason
- nickleo373
Re: KZ keys
18 Oct 2013 01:52
When i brought my bike to the dealer for a rekey it was a lot more expensive than the locksmith but they should be able to do it.
1981 KZ550C LTD
"If you ain't first, you're last"
- koolaid_kid
Re: KZ keys
18 Oct 2013 08:04
Personally, I would take it to a locksmith. It is his profession and what he does for a living. Chances are, that is exactly what the dealer does as well. They probably have a locksmith on contract to do the work for them, as I can't see them employing a locksmith on a permanent basis.
1983 GPz 750
810 Wiseco, Kerker, K&N, DynoJet S3, Accel, Progressive, etc.
Re: KZ keys
18 Oct 2013 08:46geerbangr wrote: So I have 2 keys for Oscar. 1 key works ignition switch. 1 key works gas tank. Keyhole for seat has been modified with a screwdriver by PO. Did the KZ's have 1 key that fit entire bike ? If so how do I go about correcting the issues and getting 1 key to fit the entire bike ?
ANY key should unlock the gas cap. Try the ignition key in it. The 1978 KZ1000 uses the same cap as the KZ650-C1. Those caps have no tumblers, so anything that fits in the hole will turn the cyliner that pulls back the latch. Ed
Here are the lock internals; notice the cylinder has no tumblers - it's just a slot:
Attachment IMG_0270_2013-10-18.JPG not found
- barney
Re: KZ keys
18 Oct 2013 08:57
Ditto what 650ED said. I took my seat lock on my ELR apart and re set it to my ignition key. It was really simple. Hope this helps
barney
barney
- rstnick
Re: KZ keys
18 Oct 2013 17:02 - 18 Oct 2013 23:30
Agree, take the lock you want to change apart, and see if you can rearrange the tumblers to match your key, or leave one or two out if needed.
You will probably need a new seat lock for the one that was forced with a screwdriver.
If you need a key, it can be cut by the code stamped into the lock.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2 Project
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
Last edit: 18 Oct 2013 23:30 by Patton. Reason: delete solicitation
The following user(s) said Thank You: BlackZ1R
