BIG GIRL ON BACK OF BIKE???
  • DBICK666
  • DBICK666's Avatar Topic Author
  • 1983 kz750 ltd f-1 (shaft)
10 Jul 2013 18:55
#595867
WELL I GOT A BIGGER GIRL FRIEND AND SHE WANTS TO RIDE WITH ME BUT IM LIKE 140LB AND MY GIRL IS LIKE 200 OR SO NOT TO SURE. I CAN RIDE HER ON THE BACK BUT IT SEEMS LIKE THE BACK END IS SWAYING BACK AND FORTH AND HANDLING IS KINDA POOR IS THERE ANYTHING I CAN DO TO MAKE THE BIKE MORE STABLE? BESIDES LOSEING WEIGHT WITHC SHES TRYING TO DO. ANY HELP WOULD BE NICE I HAVE A 1983 KZ750 LTD F-1 WITH ADJUSTABLE REAR SUSPENTION. THE MOTOR DOSENT STRUGGLE AT ALL WHEN WE BOTH ON IT IM JUST WORRIED ABOUT THE SWAY ON THE BACK END THANKS
Re: BIG GIRL ON BACK OF BIKE???
10 Jul 2013 19:02
#595869
You may want to adjust the air pressure in the rear tire. Check your owner's manual or the label on the bottom of the seat. They usually call for 2 more pounds of air pressure when riding with passenger. Also, you may want to set the preload a bit stiffer on your shocks so the back end doesn't move around as much. Ed
  • DBICK666
10 Jul 2013 19:16
#595875
cool thanks i got the manual i know i need new tires both front and back but ill do the air pressure first. and whats the preload and how do you set?
10 Jul 2013 19:31
#595879
Preload is the adjustment that controls how tight the springs on your shocks are set. Assuming you have normal shock and not air shocks there should be an adjustment collar on the lower end of the spring (see arrow in first pic). You can see in the pic if that collar was turned clockwise it would move up because the little ramps on the collar would lock in place against the stop that's attached to the shock body. The more you move it up - the greater the preload on the shock spring and the stiffer the rear suspension. You adjust it using a little spanner wrench (should be in tool kit) shown in second pic. Take a look in you manual and you may find reference to this adjustment. Some shocks have a second adjustment on top; if yours are that type, or if they are air shocks, the adjustment should be described in the manual. Ed
Attachment 00000_2013-07-10.jpg not found
Attachment 00000z_2013-07-10.jpg not found
  • DBICK666
10 Jul 2013 20:32
#595886
cool thanks again ill check it out and send my girl to the trainer :P
  • MFolks
  • MFolks's Avatar
10 Jul 2013 20:43
#595889
Ensure(check) the chain tensioners and axle are tight, as if they are loose, the back end will be hard to control.
  • martin_csr
  • martin_csr's Avatar
11 Jul 2013 11:03 - 11 Jul 2013 11:04
#595972
You probably ought to install new Progressive springs in the font & new shocks at the rear. You should also check the Fr & Rr wheel bearings, swing arm bearings, & triple tree, to make sure they are rock solid. Also, do any drive shaft checks. A flat tire can cause the bike to sway, so make sure the tires are good.
Most passengers don't understand the risks of motorcycling, so it is your responsibility to make sure the bike is suitable for two-up riding. Just expressing concern for the passenger. Personally, I would never get on the back of a motorcycle.
Last edit: 11 Jul 2013 11:04 by martin_csr.
  • upncummr
  • upncummr's Avatar
11 Jul 2013 11:19 - 11 Jul 2013 11:48
#595975
DBICK666:
I have a low mileage '83 KZ 750 LTD with shaft drive. It has a soft, squishy rear suspension even with preload maxed out and the damper set on its firmest setting. (It's currently in the shop getting Hagon shock/spring assemblies.)
When I asked the group about the rear suspension I was told the original factory components weren't very robust and probably needed to be replaced. It sounds like your components are probably not in any better shape than mine were.
Besides the potential mechanical issues with the bike, it's possible that your passenger is simply moving around a bit too much. If she's leaning too far in one direction or the other it could upset the handling of the bike.
Last edit: 11 Jul 2013 11:48 by upncummr.
  • trianglelaguna
  • trianglelaguna's Avatar
11 Jul 2013 17:10
#596039
34-36 psi in the rear and 32 -34 frropnt
have her scoot up tight towards you.as tight as she can get...it ,akes it like one person is the rider...trust me.... I am 300+ and my gal is trying to catch me...
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
  • peter1958
  • peter1958's Avatar
  • Banned
  • Banned
The following user(s) said Thank You: trianglelaguna
  • saxjonz
  • saxjonz's Avatar
  • KawboyZ
11 Jul 2013 21:27
#596069
Buy a moped? :evil:
79 LTD B3
  • saxjonz
  • saxjonz's Avatar
  • KawboyZ
11 Jul 2013 21:54
#596079
I ask the question: "Is that a loud exhaust or is your motor just labored?" buahuahua.
trianglelaguna wrote: 34-36 psi in the rear and 32 -34 frropnt
79 LTD B3
