visor fog
25 Jun 2013 17:01 #593910 by sig
visor fog was created by sig
It's raining here in Sacramento. Not having ridden much i decided to get a little experience riding in the rain early this morning. My visor stayed fogged at all times when it was mostly or all the way down. I have a vent in the front about mouth level but that wasn't enough. Anyone have a fix for this?
1982 KZ650H CSR
25 Jun 2013 17:33 #593914 by gengomerpyle
Replied by gengomerpyle on topic visor fog
just keep wiping it off. i used rainx once it ate the visor up and then i couldnt see nothing.
1982 GPZ750R1 ELR
1978 Honda CB750F SuperSport
1971 Honda CB750K
1970 Honda CL100 Scrambler
25 Jun 2013 18:13 #593915 by kzcurt
Replied by kzcurt on topic visor fog
Spit stops a diving mask from fogging....Spit, wipe, try again.
They also make some anti fog for googles but i dont know if it works any better then the spit.
kzc
Flag carrier #23
9 @ 50-2053,
25 Jun 2013 18:15 #593916 by upncummr
Replied by upncummr on topic visor fog
Any other vents than the one on the front of the helmet? If so they should be open.
You can also crack open the visor a little bit both when you're moving and at a standstill to improve circulation within the helmet and prevent the build-up of fog.
  • Street Fighter LTD
  • Moderator
25 Jun 2013 19:27 #593923 by Street Fighter LTD
Replied by Street Fighter LTD on topic visor fog
If its a really big problem than you can do what us snowmobilers do.
Make a breath deflector out of duct tape which directs all your expelled air from your nose and mouth down and out the bottom of your full face helmet. The secret is to seal up your eyes and shield area from your breath..
Or buy a snowmobile helmet with this feature built in and just remove it ( Its made out of Velcro and foam.) when not needed... Some also have heated shields which take care of the problem if its really extreme
Or keep spitting :woohoo:
25 Jun 2013 21:02 #593930 by zukdave
Replied by zukdave on topic visor fog
My new helmet came with a deflector.
Look your helmet up on line there should be one for it
unless it's an old helmet.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
25 Jun 2013 23:14 #593945 by NZGlenn
Replied by NZGlenn on topic visor fog
Nolan do an anti fog system called Pinlock. I have had it on my last three helmets.
it can be retrofitted to most road helmets.
It is clear (or tinted) plastic about the same thickness of your visor and it is held in to the inside of the visor by two pins, one at each side. It does not fog up at all!!
It can be unclipped afor cleaning/drying. water will run down but only after heavy rain or prolonged riding in moderate rain.. probably an hour of riding at 65mph in moderate rain will let the water in.
To retrofit you have to drill your visor, which could put some people off, or you could by a Nolan with the pins already installed
1984 GPz1100A2
25 Jun 2013 23:20 #593949 by sig
Replied by sig on topic visor fog
Thanks for the tips, I've heard about spit in goggles, will try it :P all vents are open, it has a part to help air flow but maybe it's too small.
Attachment image_2013-06-25.jpg not found
Is that what you meant by deflector?
1982 KZ650H CSR
25 Jun 2013 23:26 #593952 by Haybus
Replied by Haybus on topic visor fog
Get a Fog City and your problems will be solved. I ride year round in Seattle and it's the only thing I've found that really works. The Pinlock version works too, but only if you get the gasket to fit properly. Most motorcycle shops have them for around $20.
Alan
1976 KZ900 LTD (sort of)
2005 FJR
2009 Hayabusa
www.kzrider.com/forum/11-projects/557845...-streetfighter-build
The following user(s) said Thank You: sig
  • trianglelaguna
25 Jun 2013 23:31 #593953 by trianglelaguna
Replied by trianglelaguna on topic visor fog
well there is the problem...your head is upside down...
sig wrote: Thanks for the tips, I've heard about spit in goggles, will try it :P all vents are open, it has a part to help air flow but maybe it's too small.
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
  • trianglelaguna
25 Jun 2013 23:39 #593955 by trianglelaguna
better helmets do it too...rainx wipes help...i was watching GP and a few riders had fogging this year..enough to lose points /places....vented 2013 top design helmets with plenty of wind too....will your helmet stay open about an inch ,,,that helps me....oh and dont ride in the rain...not you unsafe...cars.....they are like 50% more likely to not see you or not stop in time....and it makes streets oily...unless you have to...then wear neon and light on and be safe...imho
1976 KZ900
2003 ZX12R
2007 FZ1000
26 Jun 2013 02:46 #593967 by sig
Haybus wrote: Get a Fog City and your problems will be solved. I ride year round in Seattle and it's the only thing I've found that really works. The Pinlock version works too, but only if you get the gasket to fit properly. Most motorcycle shops have them for around $20.
Alan
That looks great! I'll try it.
1982 KZ650H CSR
