- Thank you received: 3
visor fog
- sig
1982 KZ650H CSR
- gengomerpyle
- Thank you received: 17
1982 GPZ750R1 ELR
1978 Honda CB750F SuperSport
1971 Honda CB750K
1970 Honda CL100 Scrambler
- kzcurt
- Thank you received: 21
They also make some anti fog for googles but i dont know if it works any better then the spit.
kzc
Flag carrier #23
9 @ 50-2053,
- upncummr
- Thank you received: 16
You can also crack open the visor a little bit both when you're moving and at a standstill to improve circulation within the helmet and prevent the build-up of fog.
- Thank you received: 2061
Make a breath deflector out of duct tape which directs all your expelled air from your nose and mouth down and out the bottom of your full face helmet. The secret is to seal up your eyes and shield area from your breath..
Or buy a snowmobile helmet with this feature built in and just remove it ( Its made out of Velcro and foam.) when not needed... Some also have heated shields which take care of the problem if its really extreme
Or keep spitting :woohoo:
- zukdave
- Thank you received: 229
Look your helmet up on line there should be one for it
unless it's an old helmet.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
- NZGlenn
- Thank you received: 5
it can be retrofitted to most road helmets.
It is clear (or tinted) plastic about the same thickness of your visor and it is held in to the inside of the visor by two pins, one at each side. It does not fog up at all!!
It can be unclipped afor cleaning/drying. water will run down but only after heavy rain or prolonged riding in moderate rain.. probably an hour of riding at 65mph in moderate rain will let the water in.
To retrofit you have to drill your visor, which could put some people off, or you could by a Nolan with the pins already installed
1984 GPz1100A2
- sig
Attachment image_2013-06-25.jpg not found
Is that what you meant by deflector?
1982 KZ650H CSR
- Haybus
- Big Al
- Thank you received: 42
Alan
1976 KZ900 LTD (sort of)
2005 FJR
2009 Hayabusa
www.kzrider.com/forum/11-projects/557845...-streetfighter-build
- trianglelaguna
- Thank you received: 235
sig wrote: Thanks for the tips, I've heard about spit in goggles, will try it all vents are open, it has a part to help air flow but maybe it's too small.
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
- trianglelaguna
1976 KZ900
2003 ZX12R
2007 FZ1000
- sig
Haybus wrote: Get a Fog City and your problems will be solved. I ride year round in Seattle and it's the only thing I've found that really works. The Pinlock version works too, but only if you get the gasket to fit properly. Most motorcycle shops have them for around $20.
Alan
That looks great! I'll try it.
1982 KZ650H CSR
