Gas Tanks
- dburke
15 Jun 2013 15:54 #592436
by dburke
Gas Tanks was created by dburke
I have a 83 750 Spectre and seeing if anyone knew if a 1100 gas tank would fit it?
Thanks
Thanks
- Thank you received: 1656
17 Jun 2013 10:33 #592684
by martin_csr
Replied by martin_csr on topic Gas Tanks
A Spectre 1100? Direct bolt-on? probably not. From the diagrams, the Spectre 750 attaches differently at the rear. Also, the front mounting pegs on the frame seem to be in a different location.
For direct bolt-on, I'd guess these models.
1982 KZ750-N1 Spectre FUEL TANK
1983 KZ750-F1 LTD Shaft FUEL TANK
1983 KZ750-N2 Spectre FUEL TANK
