- Thank you received: 13
Cool old othermarket KZ400
- Roadflyer
Attachment 100_5142.jpg not found
1979 kz1000 shaftie rebuild project
1045 wiseco 10.25-1 pistons
Kenny Harmon 380 lift cams
- steell
Very nice bike!
- loudhvx
- Thank you received: 1616
I think it is a KZ400J model. It uses almost everything the KZ550A has, except the pistons, crank, cylinders camshafts and cam-timing gears. The ignition timing may be slightly different as well.
I think it uses TK21 carbs which are almost the same as the TK22 carbs found on the 550's.
In my signature, I have manuals for that bike along with a note about the valve train which you should be aware of, along with cam timing notes specific to the 400.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
- rstnick
- Thank you received: 377
I've never seen one in person.
Rob
CANADA
1978 KZ650 C2, 130K kms, Delkevic ex, EI, CVK32, PMC easy clutch, ATK fork brace, steering damper, braced swingarm, 18" Z1R front wheel.
2000 ZRX1100
2011 Ninja 250R
2005 z750s
- Roadflyer
loudhvx wrote: Yes, cool bike.
Yes, Aaron said it is a Z400-J. He and my sister ride it 2 up all over Costa Rica and even into Guatemala They own modest properties in both area's and spend the winters there.
good info about the valve maintenance issues, although I doubt he would ever take the cover off, probably better off leaving it alone rather than chance bending valves.
