- Thank you received: 15
Best combo of engine motor types that can be done
- CruisingRam
i got to thinking, if you had a pile of all three of these motors, how should they be combined to make the best possible motor, wieght, quick revs (low reciprocating mass) block strength to handle HP, longest lasting, most HP as possible and still be streetable
Say, like Z1900 crank, MK II block, J heads as a discussion starter.
1975 Z1 B 900- soon to be heavily modded
Pahoa, Hawaii is my new hom
I am working hard to save up the shipping money to get my shop opened here in Hawaii
I hate electrical stuff.
- etbike3135
- Thank you received: 50
J crank with 16 tooth center pin. MKII cases. J head. 83-84 GPZ 1100 trans converted to KZ cases.
To be honest the J motor is best all around and would be cheaper in the long run just build the bike around that.
1973 Kawasaki Z1
18 years in dragbikes
- CruisingRam
I am just curious as to the possibilities after reading some posts on the matter
- zed1015
- Thank you received: 1551
etbike3135 wrote: Money is not an object?
Same as above but shim under unitrack twin swirl head.
- CruisingRam
I am not familiar with this head- please elaborate? Can it be addapted to non-J motors?
- zed1015
Although almost externally identical to the 'J' it features larger valves (at a slightly steeper angle)and larger factory ported inlet tracts as well as a twin swirl combustion chamber (bathtub) and smaller shim under bucket shims as used on the earlier 650/750's.
The combustion chamber volume is also slightly smaller than the 'J' so the initial compression drop is not as pronounced if fitted with no piston changes but you do have to be wary of possible valve to piston interference due to the different valve angle and compensate for this by possibly having the recut the valve reliefs in the piston crown.
The same twin swirl head was used on the later z1100s (spectre etc) but these reverted back to the larger shim over bucket valve adjustment.
The unitrack heads are much sought after and go for good money but it is an unkept secret that the later z1100 ones are the same and the ones to look for at a much cheaper outlay and can be converted to shim under using z650 valve train parts if required.
- CruisingRam
When you say Z1100 are you talking GPZ 1100 or KZ1100 or just a J head in particular? Thats for the education LOL
- Powerstroke_fan
- Thank you received: 83
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
- Old Man Rock
- Thank you received: 225
You guys forgot to mention Head work (Stage 3) requirements: over sized valves and porting...
If it can't flow, she wont go.....
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- CruisingRam
- Nebr_Rex
- Thank you received: 299
CruisingRam wrote: Interesting- I had no idea. I think I will have to keep an eye out for them. A rule of thumb for any engine build is that the head is what really determines HP. Longevity is in the bottom end, but HP is in the top end is what my racer uncle used to say about his Mopars LOL
I think he Is referring to the "83 - "84 GPZ1100 head.
Which is my choice since I have the whole engine.
Plans are to bore it 1.0 over,already have the new factory pistons and rings.
Mill the heads and block just enough to sguare them and raise the static comp. ratio a little.
Degree the stock cams.
Crank, already welded.
Trans, back cut with heavier gears.
Almost new RS34s and factory Kerker hanging on the wall.
Now I just need to find a nice J model to put it in.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
- zed1015
The later z1100's are a combo of 'J' bottom end and superior GPZ style bathtub head.
They reverted back to shim over bucket on those as they were in a lower state of tune with milder cams.
