- Thank you received: 44
desiccant
- jeffasaki
17 Apr 2013 21:27 #582872
by jeffasaki
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
desiccant was created by jeffasaki
getting a little bit of moisture in one of my sheds
it has 2 of my fav bikes in it
bought a five gal pail of desicant to put inside
lets see how this works
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
- racer54
- Thank you received: 114
17 Apr 2013 21:29 #582873
by racer54
Replied by racer54 on topic desiccant
OK...what the hell is desiccant?
- jeffasaki
17 Apr 2013 21:40 #582874
by jeffasaki
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
Replied by jeffasaki on topic desiccant
ya know when you buy a new thingy and it has the little bag of silica that says dont eat
i got a 5 gallon pail of it
and will leave it open inside the shed
when it stays closed for extended periods of time
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
- MFolks
- Thank you received: 540
17 Apr 2013 22:07 #582878
by MFolks
Replied by MFolks on topic desiccant
Or get a "Golden Rod:, a low wattage heater designed to keep moisture away.
www.goldenroddehumidifiers.com/faqs.htm
- KZErider
- Thank you received: 12
17 Apr 2013 22:59 #582896
by KZErider
81 KZ750E2(project), 81 KZ750E2(parts donor), 87 BMW K 75C - got it runnin, didn't care for it, holding for family member, 79 CB650(project) Nomad 1700, VStar 950
Replied by KZErider on topic desiccant
Dirt floor?
- jeffasaki
17 Apr 2013 23:01 #582897
by jeffasaki
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
patio stones and 2x4s
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
- bluej58
- Thank you received: 511
- kzcurt
- Thank you received: 21
18 Apr 2013 14:52 #582964
by kzcurt
Flag carrier #23
9 @ 50-2053,
Replied by kzcurt on topic desiccant
It more than likely is condensation from temperature change? I actually put carpet down to stop the cement from sweating, worked great, for the cement, however the bike or the gas tank or,or,or...once they hit the 'dew point' will still sweat. The only thing i do to stop it, is try to avoid opening it up when there is a sudden increase in temperature!
Flag carrier #23
9 @ 50-2053,
- TomW
- Keep the blue side up.
- Thank you received: 52
19 Apr 2013 10:49 #583079
by TomW
'78 KZ1000B2 LTD stock + Vetter Fairing & luggage
'91 ZG1200B5 Voyager XII, stock
Replied by TomW on topic desiccant
Even easier, put the bikes in the living room.bluej58 wrote: Gutters and drain tile
- Online
- Thank you received: 2061
19 Apr 2013 11:04 #583083
by Street Fighter LTD
Replied by Street Fighter LTD on topic desiccant
- jeffasaki
15 May 2013 08:08 #587497
by jeffasaki
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
3 weeks in the shed
both bikes nice and dry
for my app this has worked very well
cost $70
dry bikes in the wet thaw out season
equals
worth it
NO CONDENSATION
at all
cost $70
equals
worth it
NO CONDENSATION
at all
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
