- Thank you received: 11
chain cleaner
- donthaveakawman
- Visitor
27 Feb 2013 18:18 #574440
by donthaveakawman
chain cleaner was created by donthaveakawman
my cycle chain has been dirty for a while and I cleaned it with a nylon brush, but it just doesn't seem to do the trick. I got some grunge buster degreaser and it cleaned up pretty well. the issue now is the chain has a little side to side movement that I am not sure about.
Attachment grungebuster.jpg not found
- mick z1a
27 Feb 2013 19:06 #574447
by mick z1a
Replied by mick z1a on topic chain cleaner
put some gunk back, that should take up some of the slack
- DoubleDub
- Visitor
27 Feb 2013 22:09 #574479
by DoubleDub
Replied by DoubleDub on topic chain cleaner
Simple green in a bucket works fine.
- donthaveakawman
- Visitor
27 Feb 2013 22:16 #574481
by donthaveakawman
Replied by donthaveakawman on topic chain cleaner
ok, so obviously engine degreaser would not work. what about soap and water? palmolive= tough on grease easy on hans?
- Thank you received: 1656
27 Feb 2013 23:13 - 25 Jun 2013 09:56 #574490
by martin_csr
Replied by martin_csr on topic chain cleaner
I've heard of the o-rings crumbling, so I guess you could check to see if yours are intact. Perhaps the chain is shot, hence the excessive movement?
Last edit: 25 Jun 2013 09:56 by martin_csr.
- mik3mac
24 Jun 2013 23:36 #593810
by mik3mac
1976 kz900 custom
Replied by mik3mac on topic chain cleaner
Strong arm spray is what your looking for it will do the job. $18 after shipping you'll love it its a motorcycles best friend chrome rust remover cleans every inch of your bike from Carb gas leak stains to rims and exspecially your chain this stuff leaves a protective waterproof coating that blocks dirt. Check out some YouTube videos of Strong Arm Spray.
1976 kz900 custom
- GregZ
- Thank you received: 88
25 Jun 2013 07:27 #593839
by GregZ
Replied by GregZ on topic chain cleaner
Diesel
