- Thank you received: 16
The most interesting engine evolution yet
- KZ250LTD
19 Feb 2013 23:44 #573259
by KZ250LTD
79 KZ1000ST
Past:
Many.
The most interesting engine evolution yet was created by KZ250LTD
/Drive on youtube has been doing a series from inside the Koenigsegg factory for the past few months. This is the most interesting one yet, air controlled valves. No more camshafts, cam chains, etc. Electronically individually adjustable valve timing. Crazy.
79 KZ1000ST
Past:
Many.
- bluezbike
- Thank you received: 104
20 Feb 2013 00:50 #573271
by bluezbike
79 KZ 1000 LTD
Replied by bluezbike on topic The most interesting engine evolution yet
That's pretty amazing...and the numbers he is talking about make so much sense
79 KZ 1000 LTD
- Thank you received: 2829
20 Feb 2013 01:35 #573278
by 650ed
Replied by 650ed on topic The most interesting engine evolution yet
That is pretty cool. I wonder what safeguards are built in just in case you lose air pressure while the engine is running; maybe the valves automatically close to avoid piston/valve contact? Ed
- KZ250LTD
20 Feb 2013 03:58 #573287
by KZ250LTD
Not sure, I suspect from the way he was describing them that maybe they'll operate on a spring similar to current valve springs so the default position will be closed.
79 KZ1000ST
Past:
Many.
Replied by KZ250LTD on topic The most interesting engine evolution yet
650ed wrote: That is pretty cool. I wonder what safeguards are built in just in case you lose air pressure while the engine is running; maybe the valves automatically close to avoid piston/valve contact? Ed
79 KZ1000ST
Past:
Many.
- Steely
03 Mar 2013 17:21 #575087
by Steely
Replied by Steely on topic The most interesting engine evolution yet
Something similar has already been done by an ordinary person. I used to belong to a Supra forum and a guy had retrofitted electronic solenoids to control the valves on a mk3 Supra. He had a turbo inline 6 revving to 18k I believe
- steell
03 Mar 2013 22:08 - 03 Mar 2013 22:13 #575153
by steell
Replied by steell on topic The most interesting engine evolution yet
Formula One cars have been doing that for a while now. Have you seen the videos of the F1 cars playing National Anthems from various countries? Just search youtube for Renault music
Totally computer controlled:
Last edit: 03 Mar 2013 22:13 by steell.
- donthaveakawman
- Visitor
03 Mar 2013 22:32 #575160
by donthaveakawman
yep
Replied by donthaveakawman on topic The most interesting engine evolution yet
Attachment 528412_302295296564413_14425757_n.jpg not found
yep
