- Thank you received: 5
Fuel pump and dyna coils
- NZGlenn
and a set of Dyna Coils off Z1.
Really fast service from both companies, 5 days delivery to New Zealand door to door.
With the way the US dollar is going it makes it less expensive to buy and ship from the states.
I will fit these on the weekend if I've got time.
1984 GPz1100A2
- Motor Head
- Thank you received: 391
Pictures of the bike will always be appreciated around here also.
- wagonmaster69
- 78 KZ1000A2 / 82 KZ1100 Spectre
- Thank you received: 4
- NZGlenn
I have just pulled the old pump out.
It was fairly easy, remove the
seat, tank, and side covers
Remove the battery and put on the charger.
Disconnect the wiring around the battery holder
unbolt the inner mudguard.
Unbolt the battery holder. This allows the battery holder to be angled, to get to the pump clamp.
Remove the pump clamp,
remove the hoses.
pull the pump out.
I put the new pump in position and confirmed one of my potential issues. the straight hose outlet is too long. it needs one like the factory one which has a 90' bend on it.
Hopefully I'll be able to source an adapter locally, as I can't find anything on google. I might get one manufactured if all else fails.
1984 GPz1100A2
- wagonmaster69
- NZGlenn
Need it for the fuel injection
1984 GPz1100A2
- 0Z.Z1R Mk2
- Thank you received: 31
Great little unit...
- NZGlenn
1984 GPz1100A2
- Lorcan
- Speed Loony
- Thank you received: 59
0Z.Z1R Mk2 wrote: Ive been running a Walbro GLS393 fuel pump for years now on the 750turbo.
Me too
760cc - 8.69@162mph
810cc, 211mph www.750turbo.com
www.stormdragbike.com
- 0Z.Z1R Mk2
NZGlenn wrote: Hi, how did you do the right angle bend on the outlet of the fuel pump?
IIRC...Just got one from my local auto parts shop.
A lot of carb fittings are similar.
- NZGlenn
We have Repco, which typically staffed by people who know how to read a parts manual only. If you're looking for a part to fit something non-standard they look at you like you're stupid.
The other one is Super Cheap Auto, which is slightly better at customer service but they seem to cater for people who want cheap oil and wiper blades.
SoI went to a car performance shop. told the guy what i had and what I needed it to do. Halfway through my explaination, he grabs the exact parts out of the display case.
This is a thumbs up for local shops instead of chain stores. The price was probably a lot more than Repco, but I had expert, quick help.
1984 GPz1100A2
