- Thank you received: 1616
Neutral or First Gear at a Traffic Light ???
- donthaveakawman
- Visitor
07 Feb 2013 02:52 #571224
by donthaveakawman
Replied by donthaveakawman on topic Neutral or First Gear at a Traffic Light ???
I think I have been getting electrified through my clutch cable, but common sense tells me it is the muscles in my arm are frictioning.
- loudhvx
07 Feb 2013 13:37 #571284
by loudhvx
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Replied by loudhvx on topic Neutral or First Gear at a Traffic Light ???
On a car, riding the clutch wears out the throwout bearing and pressure plate fingers.
On the KZ, when you hold the clutch in, at a stop, the part that gets pressed out (the pressure plate) is at a stop, so there is no wear like in a car. It doesn't hurt hte trans at all. The springs may get softer sooner, or maybe the disks might wear a tiny bit, but that means they will only last 40 years instead of 50.
1981 KZ550 D1 gpz.
Other links.
- baldy110
- Thank you received: 512
07 Feb 2013 14:17 #571297
by baldy110
That will eventually get you hurt, ask Mark Wing. Never assume that cars are going to stop just because their light just turned red and yours just turned green.
Replied by baldy110 on topic Neutral or First Gear at a Traffic Light ???
donthaveakawman wrote: actually I usually like to avoid traffi.c hours and slow down alot before the light in neutral then coast until the light turns green
- donthaveakawman
- Visitor
08 Feb 2013 04:04 #571451
by donthaveakawman
of course I have run a few lights now and again.
- gengomerpyle
- Thank you received: 17
08 Feb 2013 14:50 #571494
by gengomerpyle
1982 GPZ750R1 ELR
1978 Honda CB750F SuperSport
1971 Honda CB750K
1970 Honda CL100 Scrambler
Replied by gengomerpyle on topic Neutral or First Gear at a Traffic Light ???
same here
baldy110 wrote: All depends on how long the light is.
1982 GPZ750R1 ELR
1971 Honda CB750K
