KZ1000P-17 is a FAT PIG!!!
- SBK Racer
23 Dec 2012 00:02 - 23 Dec 2012 00:32
I do not know if anyone has mention this or not... But the KZ1000P-17 is a FAT PIG!!!
Today, I decided to give it a good clean... That upper fairing has to weight some 65-70 lbs... The saddlebags and guard are like 25 lbs each... The rear bumper(?) is a good 10 lbs...
The previous guy apparently did ZERO maintenance on this bike... I spend a good 3 hours on the chain... Removed the left shock and got to clean until the kerosene was coming clear.
The chain seems to be a Kawasaki ZZR1200 530 chain EK50 ZVX2. The Rear Sprocket looks like new and it's 46 tooth...
Engine degreaser and lots of Simple Green... Then a careful rinse with the power washer... Being careful not to get the electrical parts too wet... Then dried with pressure air...
These foot platforms I would like to replace with rear sets...
But there is not a lot of options where to mount rearsets...
Luis
MOTORCYCLES ARE DANGEROUSLY FUN!!!
A good street rider uses judgment, to avoid situations that require superior skill...
A good track rider uses superior skill, to seek situations that define their judgment...
1998 KZ1000P-17 - 2004 PW80 Pit Bike - 2005 SV650R - 2006 SV650 - 2006 GSXR750 - Soon day...
Last edit: 23 Dec 2012 00:32 by SBK Racer.
- guitargeek
Re: KZ1000P-17 is a FAT PIG!!!
23 Dec 2012 00:33
You're spoiled by all this modern machinery.
Put it in perspective, think back to what this bike was up against in the early 80s.
You were around back then, right?
1987 KZ1000-P6 "Ponch"
1979 GS1000 "Dadzuki"
- guitargeek
23 Dec 2012 00:38
- SBK Racer
23 Dec 2012 00:51That is my other bike 352 lbs with a fuel tank of fuel... I guess I am spoiled rotten!!!
The KZ1000P is a 1998... But I understand it probably did not change much since 1977, (I was Born Sep 1977)
I know this is not an ultra high performance machine... It's a nice Motorcycle!!! This bike will probably not see forged wheels, billet alloy machined parts, titanium hardware, or carbon fiber. ...But I am going to put this KZ1000 on a diet!!!
I think I can easily shave 100 lbs of unnecessary equipment not needed outside of Police service... After my cleaning the motorcycle, I put it all back together, including the 5 lbs chain guard...
- Charles Nix
- 1981 kz 1000c4
23 Dec 2012 01:32
When I picked up mine the brakes were locking down ,had to lube the brake rotors.The chain was too tight because of ,the swing arm being cracked,front left ,and that god awful fairing in the way when you push it by yourself! Pictures of dissasembly.
- guitargeek
23 Dec 2012 02:11 - 23 Dec 2012 02:51
Luis, I'm afraid you're only going to be disappointed with this ancient machine, and I'm a little confused about what you're doing with it in the first place.
I'm building mine into a touring rig, not that much of a stretch: Big, comfy seat, floorboards, big fairing, heavy duty charging system, etc.
Old bikes are heavy and slow compared to modern bikes, sure, but they're simple and fairly cheap.
Ponch will never beat a Panigale around the Nurburgring... but it doesn't have to.
Last edit: 23 Dec 2012 02:51 by guitargeek. Reason: Spelling & punctuation.
- SBK Racer
23 Dec 2012 06:20 - 23 Dec 2012 06:24
Oh I still think it will be a fun bike... Not just to ride but also to work on it... Especially once I review every part and bolt on the chassis and re-engineer it to my liking...
I had to stop my self from buying parts today, because I actually want to have have a clearer idea of what I want...
I think I want lighten it up a bit first, I know the Police fairing is going to come off. I am definitely going with a simple round headlight... I saw a KZ1000 LTD front fender I like much better than the KZ1000P front fender.
I am going to hold off to front end and rear end conversions... But, I am going to work with the suspension... Firm it up a little. I am buying some ZRX1200R adjustable KYB shocks... These look to be a simple bolt on operation.
If I am not mistaken the stock fork spring rate is 0.620 kg/mm. I am probably going to install stiffer springs on the front... I think with 1.0 kg/mm springs the bike will handle better and wont dive as much when I brake. Also a Gold Valve Cartridge Emulator kit from Racetech would be a good call.
This will keep me busy for a little bit...
I would like modern brakes, and steel braided brake lines...
I would like to remove the big foot rests, in favor of standard foot pegs and foot controls...
I would like lower handlebars...
This looks nice too...
Luis
Last edit: 23 Dec 2012 06:24 by SBK Racer.
- donthaveakawman
23 Dec 2012 09:32 - 07 Jan 2013 05:28
sorry, this video was not my own. I had no right to copy and paste it here.
Last edit: 07 Jan 2013 05:28 by donthaveakawman.
- testarossa
23 Dec 2012 11:26
Something to consider when fitting the LTD fender. The LTD bikes all had leading axle forks and your police model has the axle center mounted. It may not center the fender over the tire properly. Also I believe that the police front end has a wider spacing between the fork tubes than a normal KZ. Not saying you can't fit it, but it might not be an easy bolt in. Good luck with your project.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
2004 ZX-10R
Angola, IN
The following user(s) said Thank You: wireman, SBK Racer
- donthaveakawman
23 Dec 2012 11:59 - 07 Jan 2013 05:29
I am gaining from someone else's loss
Last edit: 07 Jan 2013 05:29 by donthaveakawman.
- donthaveakawman
23 Dec 2012 12:44Charles Nix wrote: When I picked up mine the brakes were locking down ,had to lube the brake rotors.The chain was too tight because of ,the swing arm being cracked,front left ,and that god awful fairing in the way when you push it by yourself! Pictures of dissasembly.
How, hi are you. this is chief wampum of the throttlefeather tribe I wanted to ask you what you think of those handlebars. they appear similar to mine. I don't like them that much, they hurt my wrist being so close together.
- SBK Racer
23 Dec 2012 15:55 - 23 Dec 2012 15:59donthaveakawman wrote:
Just like some of us practice on a race track, and get better at going fast at the limit of traction...
Police does training and practice those curses on a regular basis... It is very impressive!!!
testarossa wrote: Something to consider when fitting the LTD fender. The LTD bikes all had leading axle forks and your police model has the axle center mounted. It may not center the fender over the tire properly. Also I believe that the police front end has a wider spacing between the fork tubes than a normal KZ. Not saying you can't fit it, but it might not be an easy bolt in. Good luck with your project.
I did noticed that... Thank you!!!
Last edit: 23 Dec 2012 15:59 by SBK Racer.
