- Thank you received: 17
octane rating
- donthaveakawman
- Visitor
octane booster for the most part, if you get the cheap stuff is basically upper cylinder lubricant. 10 points equals 1 octane rating, so nos racing formula octane booster(raises octane 60 points) when added to 92 octane gas would equal 98 octane. and 14 dollars gets a 12 oz bottle, which treats 16 gallons of gas. as you can see 10 points equals 1 octane rating. when added to 87 octane gas would make 93 octane, and 92 octane is close for 20-30 cents per gallon more.
- donthaveakawman
- Visitor
- donthaveakawman
- Visitor
higher octane gas is harder to ignite, but burns more thoroughly. If I remember right I read up on gas octane from the 60's I think it was, and the octane rating was about a hundred. probably due to lead and 12 to 1 compression on a factory car.donthaveakawman wrote: 87 cents per gallon to make 87 octane into 93 octane. I think I will stick with the 92 octane for 20-30 cents more.
- gengomerpyle
1982 GPZ750R1 ELR
1978 Honda CB750F SuperSport
1971 Honda CB750K
1970 Honda CL100 Scrambler
- DoubleDub
- Visitor
- steell
Calculated compression, actual compression was 9:1
Lot's of overlap kills compression, and that's how they were able to advertise those high compression numbers.
- Del_Herring
- Thank you received: 29
Doesn't make sense to advertise dynamic compression, since it's one of the first things people will change if they start tuning, or if you have an engine with VVT.
1983 KZ750-N2 Spectre
- donthaveakawman
- Visitor
