- Thank you received: 36
Over-, under- or perfect gearing?
Poll: Gearing preference (was ended 0000-00-00 00:00:00)
Undergeared for instant acceleration |
5 | 45.5% |
Overgeared for relaxed cruising |
3 | 27.3% |
Perfect gearing for maximum top speed |
3 | 27.3% |
Gearing??? |
No votes | 0% |
Total number of voters: 11 | |||
Only registered users can participate to this poll |
- faffi
22 Jun 2012 08:32 #530967
by faffi
1977 KZ650B1
1980 F1 engine
B1 3-phase alternator
B1 Points ignition
Over-, under- or perfect gearing? was created by faffi
I will admit that I enjoy instant arm-straightening acceleration in top gear at any speed. None of that down-shifting to find power, just twist the loud handle and GO! However, I also enjoy cruising at as few rpm as possible, both because it's more relaxing and because it's more econimical on fuel and wear.
I'm not interested in top speed, and as such I should run my bikes undergeared for maximum performance. But in everyday use, I find that it's better to change down a gear or two for passing power than to run with the engine screaming away while cruising. So I generally gear up when it's time to fit new chain and sprockets.
What about you?
What about you?
1977 KZ650B1
1980 F1 engine
B1 Points ignition
- wireman
- Thank you received: 299
22 Jun 2012 08:35 #530969
by wireman
Replied by wireman on topic Over-, under- or perfect gearing?
I like big motors.
That way you dont have to downshift most of the time,just roll on the throttle and hang on! :woohoo:
- faffi
23 Jun 2012 17:40 #531295
by faffi
Yes, big engine torque is nice The biggest problem is not getting into trouble because it's so intoxicating to twist the throttle. A nice compromise would be something like the early 4-speed Vulcan 1500 engine fitted into a standard chassis. That bike, along with the early Intruder 1400, offered top gear acceleration on par with the V-max 1200 and in a lighter bike would kill the same Mr. Max. But they would not be fast in that acceleration really starts to drop past 80-90 mph.
1977 KZ650B1
1980 F1 engine
B1 Points ignition
Replied by faffi on topic Over-, under- or perfect gearing?
wireman wrote: I like big motors.
1977 KZ650B1
1980 F1 engine
B1 Points ignition
- rstnick
- Thank you received: 377
23 Jun 2012 19:15 #531315
by rstnick
Rob
CANADA
1978 KZ650 C2, 130K kms, Delkevic ex, EI, CVK32, PMC easy clutch, ATK fork brace, steering damper, braced swingarm, 18" Z1R front wheel.
2000 ZRX1100
2011 Ninja 250R
2005 z750s
Replied by rstnick on topic Over-, under- or perfect gearing?
When I bought my last sprockets for my kz650, I stayed with the stock gearing 16/42 after thinking long about switching.
I find the stock gearing works well for me.
Most of my riding is country roads at 80+ KPH.
I do little highway riding, but even when I do I find the 650 has enough power for me.
I've only had her up to 160 kph, and have not had her full out in 5th.
160 is plenty fast for me.
50 over the limit here is an automatic licence suspension, and fines.
I do admit to sometimes trying for that non existant 6th gear though.
:laugh:
:laugh:
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R
2005 z750s
- 4TheKZ1000
- Visitor
23 Jun 2012 19:33 - 27 Jul 2012 17:47 #531317
by 4TheKZ1000
Replied by 4TheKZ1000 on topic Over-, under- or perfect gearing?
im a 14 - 35 guy.....its about 2.50 final drive. 630 chain
Last edit: 27 Jul 2012 17:47 by 4TheKZ1000.
- bluej58
- Thank you received: 511
23 Jun 2012 20:09 #531325
by bluej58
78 KZ1000 A2A
Replied by bluej58 on topic Over-, under- or perfect gearing?
Stock sprockets, plenty of power for me and 45.1 mpg to boot
78 KZ1000 A2A
- djturnz
27 Jul 2012 15:02 #539027
by djturnz
1982 KZ750 (4) LTD
Replied by djturnz on topic Over-, under- or perfect gearing?
When my 750 needed sprockets and chain, I did the 530 conversion and went the equivalent (thanks Z1) of 1 up in front, and 2 down in the rear. I was going for a comfortable cruise over a stop light drag launch. I sometimes think it's a little too tall. I've since bought a -1 front sprocket, but haven't installed it yet.
1982 KZ750 (4) LTD
