Speed on highway
- Ultrastar87
- 1979 KZ1000 Shaft
05 Apr 2012 07:53 #514150
by Ultrastar87
Full throttle, whenever, wherever, to the very end
Speed on highway was created by Ultrastar87
I ride the '79 KZ1000 shaft...
I hit around 65 mph @ 5k rpms on 5th gear. Is that normal?
I am a complete rookie with bikes, so I don't know.
But sometimes it feels like the bike doesnt display all of its horsepowers
or maybe is it that the KZ doesnt show its colors until I hit higher revs?
- Powerstroke_fan
- Thank you received: 83
05 Apr 2012 08:25 #514151
by Powerstroke_fan
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
Replied by Powerstroke_fan on topic Speed on highway
Not sure on what gearing the shafties run. but the bike will make decent power at higher revs. but also should be making decent power at 5k.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
- DiamondSkyBlue1000
- Thank you received: 40
05 Apr 2012 13:46 #514201
by DiamondSkyBlue1000
Replied by DiamondSkyBlue1000 on topic Speed on highway
That sounds about right for stock.
If you have the stock carbs and air box, yeah, it will seem to be a little lean at that speed/RPM's.
Thanks to the EPA and Jimmy Carter and the 55mph national speed limit back then!
- Nebr_Rex
- Thank you received: 299
05 Apr 2012 22:46 #514281
by Nebr_Rex
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
Replied by Nebr_Rex on topic Speed on highway
Run some Sea Foam or B12 in a tank full of your local high octain gas.
Stock jets are 110s,they might have a little build up internally.
I suggest getting a repair manual for the bike and read thru it.
You will have a better understanding of any 'help' you'll receive here.
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
