- Thank you received: 3
oops.. dropped it into the crankcase..
- murr50
I tried to look down with a flashlight to see if the allen key was there, but no luck. I am really hoping that it fell right down into the oil pan. Luckily I also was going to change the oil and filter tonight, so I drained the oil, and removed the filter. Took off all the bolts to remove the oil pan, and its stuck. Banged on it with a rubber mallet for 30 minutes until I finally gave up. Tomorrow I will try a hammer and a piece of wood.
Anyways, just opening up the thread to anyone else who has had a similar idiot moment that resulted in a huuuuuuge pain
1977 kz650 C
- nobody
- Thank you received: 7
- apbling
- Thank you received: 12
Then, when I had to drop my 550 pan, I planned ahead and cleared the whole day for the job. The little bugger came all off in one piece
- Thank you received: 2098
:woohoo: :laugh: :laugh: :laugh:apbling wrote: ...sucked big time. Like, epic suckage....
- loudhvx
- Thank you received: 1616
apbling wrote: When I had to drop my oil pan on my 750, I spent about a day scrapping off all the bits of gasket that was baked on. That sucked big time. Like, epic suckage.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
- murr50
What are the chances of the allen key doing any damage down there? I have seriously tried getting the oil pan off for over 2 hours. If I just leave the allen key in the bottom will it should be heavy enough to stay put, right?
1977 kz650 C
- richrand
- Thank you received: 4
While removing my Kz's head, one of the four small plates that are part of the cam tower assembly fell into the case. I removed the oil pan and drained it clean but there's no sign of the missing part. Any idea where this could be hidding? Is there an area under the crank where the cam chain is that it could be sitting in?
- Medina
- Thank you received: 8
Ol' Tommy was showing off the rather elaborate 3-2 carb set up he had. Three nice sets of two bore carbs.
ol tommy dropped one of the wing nuts into said two bore (rochesters, I cant remember) and thought, there is no way it can get past anything......so ol tommy fired it up and for some reason jumped the gas....now back in 1976 you could still get real gas, and that real gas mixed with some real air and sucked that wing nut into one of the pistons, blew his engine, we heard it about a block or so away.
I've done many stupid things, but always got lucky fishing them back out. Good luck, we're pulling for ya
1981 KZ1100 Vetter "Luminous Navy Blue" DAMN YOU COLOR CODES!
Medina, Oh
My Bike Thread
www.kzrider.com/forum/10-new-members/469298-from-ohio
- OKC_Kent
Oklahoma City, OK
78 KZ650 B2 82,000+ miles
- DesmoBro
- ~Building a Fish~
Good Luck Def don't drive it like that~!
www.dotheton.com/forum/index.php?topic=34163.0
~~^^Fish in Progress^^~~
- richrand
- richrand
