82 550 ltd max speed (please help)
- ditchdriver
20 Mar 2012 22:16 #510927
by ditchdriver
1982 kz 550 ltd
Grand Forks, ND
82 550 ltd max speed (please help) was created by ditchdriver
ok for all you gurus out there i need an answer i got my permit for my bike and took it out for a ride today. my speedo is working properly i was with the flow of traffic so i know i wasnt going over. SO why in the hell is my max speed 45 freakin mph in 6th gear. i counted every shift and it would go no higher but it was reving high at 45 like 6 or 7 grand is this usual for this bike or has someone changed something please help
1982 kz 550 ltd
Grand Forks, ND
- Thank you received: 2829
20 Mar 2012 22:32 - 20 Mar 2012 22:33 #510932
by 650ed
Replied by 650ed on topic 82 550 ltd max speed (please help)
Your clutch is probably slipping. Try adjusting it according the the instructions in the manual and it may be ok. Ed
Last edit: 20 Mar 2012 22:33 by 650ed.
- baldy110
- Thank you received: 512
21 Mar 2012 21:41 #511119
by baldy110
Replied by baldy110 on topic 82 550 ltd max speed (please help)
What he said
- Thank you received: 1656
22 Mar 2012 10:15 - 21 Feb 2013 15:39 #511212
by martin_csr
Last edit: 21 Feb 2013 15:39 by martin_csr.
- apbling
- Thank you received: 12
22 Mar 2012 10:54 - 22 Mar 2012 10:54 #511221
by apbling
Replied by apbling on topic 82 550 ltd max speed (please help)
Does it have power low end?
When you pull away from a stop or really get on her through the gears does it feel like it slips at all?
When my clutch was going, it would slip badly on take offs and when I really got on her through the gears. Eventually it slipped so bad it wouldn't even pull away from a stop.
It might even be time for new clutch disks and springs. There is a thread on here where you can take your clutch apart, clean the disks and rough them up a bit with a scotch brite pad and then you can just replace the springs with new ones. This is only if the disks pass the thickness spec outlined in the manual. I did this on my 750 after it was slipping and the issues went away for at least 5k miles, and then I sold it.
Other than the clutch slipping, I guess a possibility is that someone changed the sprockets to the obscene low end, but I doubt it's even possible, and if it was the old girl could pull the front end up in the first 3 gears...haha. I can vouche that my 82 550 will easily wrap the needle past 85.
Last edit: 22 Mar 2012 10:54 by apbling.
- loudhvx
- Thank you received: 1616
22 Mar 2012 12:50 #511245
by loudhvx
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Replied by loudhvx on topic 82 550 ltd max speed (please help)
I have a speed calculator in my signature, if you know the rear tire dimensions and your sprocket teeth.
I also have a guide for the clutch actuator adjustment. The one in the aftermarket manual is wrong for the 3-ball-ramp type actuator (which is what your bike should have).
There are also several manuals in my signature. Grab all of them.
1981 KZ550 D1 gpz.
Other links.
