- Thank you received: 2098
Routine lube points
18 Feb 2012 15:56 - 19 Feb 2012 02:14 #504887
by Patton
Routine lube points was created by Patton
Routine lube points
Especially after washing, I routinely add a smidgen of oil to the:
handlebar lever pivot points
exposed external carb linkage
foot brake pivot
foot peg pivots
seat hinges
seat lock
tank cap lock (where applicable)
drum brake rod ends (if applicable)
swivel on kick start
kick stand pivot
Plus sometimes a spritz of WD40 into the switches to displace any moisture, followed by blowing out with compressed air. Sorry, MFolks , as I suspect that Deoxit would indeed be a better choice.
A grease nipple on the swingarm pivot is nice to have, and wish all bikes were so equipped.
Have thought about adding a grease nipple to that location, but never tried it.
foot brake pivot
foot peg pivots
seat hinges
seat lock
kick stand pivot
Last edit: 19 Feb 2012 02:14 by Patton.
- rstnick
- Thank you received: 377
19 Feb 2012 01:59 #504988
by rstnick
Rob
CANADA
1978 KZ650 C2, 130K kms, Delkevic ex, EI, CVK32, PMC easy clutch, ATK fork brace, steering damper, braced swingarm, 18" Z1R front wheel.
2000 ZRX1100
2011 Ninja 250R
2005 z750s
Replied by rstnick on topic Routine lube points
Good reminder to lube up critical points periodically.
Also a good time for a visual check of the bike.
From the owners manual:
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R
2005 z750s
