vin nr on chassis and engine??
- gmarais
17 Feb 2012 02:51 #504536
by gmarais
1981 kz750e2- old rustbucket project
vin nr on chassis and engine?? was created by gmarais
Hi fellow owners.
I contacted my local spares and parts dealer to find out whether they might stock a starter clutch kit or do they need to order one. Logically they had to order it and asked for the chassis nr as reference at kawasaki. They came back to me a bit later informing me that the nr doesn't show on their database at all.
Now I know that this old rustbucket didn't have any papers when I bought it so I went to our police station to check if this might be a stolen bike or if it was in an accident at some time during its life. They also informed me that the bike wasn't on their system at all. No record of an accident. No record of a previous owner. No record of registration. Nothing. Nada. -they did say that registration after restoration/repair/rebuild would not be a problem though-
My question is: did this happen to any other owner before? And how is it possible that kawasaki doesn't have this nrs on their database?
Just a bit confused??
- osage
- Thank you received: 4
17 Feb 2012 06:11 - 17 Feb 2012 06:12 #504544
by osage
1976 KZ750B1
1982 KZ750H3
Replied by osage on topic vin nr on chassis and engine??
Can't answer why they can find it. I was able to pull it up from owners info on kawasaki.com. Both 81 750's come up under as 740cc when you search for it. All the parts numbers are there for starter and starter clutch. Rollers and springs for clutch are active as are the brushes in the starter.
I don't know how things outside the U.S. work for dealers.
On a side note I was able to enter frame number for one of my bikes. I found it was a kz750H3 instead of the H2 as my state lists it. So you might try that on the website.
1976 KZ750B1
1982 KZ750H3
Last edit: 17 Feb 2012 06:12 by osage.
- Mcdroid
- Gone Kwackers
- Thank you received: 316
17 Feb 2012 07:14 #504545
by Mcdroid
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Replied by Mcdroid on topic vin nr on chassis and engine??
So, what is the frame VIN?
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- Thank you received: 2098
17 Feb 2012 08:39 - 17 Feb 2012 08:40 #504550
by Patton
Replied by Patton on topic vin nr on chassis and engine??
Per Zedder:
'81 KZ750-E2
Frame No. Range (old) KZ750E-012001 - 013721
New VIN Range JKAKZDE1vBA013722 - 032400
Engine No. Range KZ750EE024601 - 062600
Per Zedder:
'81 KZ750-E2
Last edit: 17 Feb 2012 08:40 by Patton.
- Thank you received: 1656
17 Feb 2012 09:39 - 19 Feb 2013 12:45 #504559
by martin_csr
Last edit: 19 Feb 2013 12:45 by martin_csr.
17 Feb 2012 09:50 #504561
by Patton
Lots of good info on kawasaki.com, including parts diagrams, part names, part numbers, models sharing same part, availability, etc. Here's a link for help with navigating the site and finding information.
kzrider.com/index.php?option=com_kunena&...w&catid=13&id=376734
