Help with bike ID?
- xbmxxx
08 Feb 2012 01:09 #502703
by xbmxxx
76 KZ750B Twin
Help with bike ID? was created by xbmxxx
This is one I am working on, just trying to figure out the year. The part that's confusing me is that my 750b has points, and this one has wires coming out the points cover.
76 KZ750B Twin
- roy-b-boy-b
- Thank you received: 103
08 Feb 2012 10:03 #502765
by roy-b-boy-b
Replied by roy-b-boy-b on topic Help with bike ID?
- Thank you received: 2829
08 Feb 2012 10:12 #502766
by 650ed
Replied by 650ed on topic Help with bike ID?
1980 KZ750-G1 (LTD II).
- steell
08 Feb 2012 14:44 #502797
by steell
Replied by steell on topic Help with bike ID?
Yep, 1980 KZ750G1.
Uses points just like the 750B unless it's been upgraded to electronic ignition.
Most parts will swap with 750B, my avatar is a 750B with 750G side covers and tank.
- Thank you received: 2098
08 Feb 2012 17:15 - 09 Feb 2012 03:35 #502820
by Patton
Replied by Patton on topic Help with bike ID?
Is engine possibly from USA market's 1982 M1 (engine numbers KZ750BE053510~) having oem electronic ignitions according to wiring diagram in the FILEBASE)?
Last edit: 09 Feb 2012 03:35 by Patton.
- xbmxxx
08 Feb 2012 22:31 #502876
by xbmxxx
76 KZ750B Twin
Replied by xbmxxx on topic Help with bike ID?
Awesome, thanks guys. The electronic ignition looks to be factory, but thats not saying someone before me hasn't swapped it.
One more question, would this engine use the same carbs as my 76 KZ750B?
heres a few pics.
heres a few pics.
76 KZ750B Twin
- steell
09 Feb 2012 02:15 - 09 Feb 2012 02:19 #502919
by steell
Sorta kinda, but they do interchange
That is an 82 motor, it's got the small manifolds for the BS34's installed on the 82 and later twins, Does it have two hose connections on top the valve cover?
82 has electronic ignition stock.
The 79 in my avatar has an 82 motor in it
Last edit: 09 Feb 2012 02:19 by steell.
