- Thank you received: 288
Parts cross referencing
- les holt
03 Jan 2012 19:31 #496131
by les holt
Parts cross referencing was created by les holt
I know you can use bike bandit to do it, I just haven't been there for a while and it looks different and I can not find how I done it before. Can someone help me get it?
Thanks
Les
Thanks
Les
- wireman
- Thank you received: 299
03 Jan 2012 19:34 #496132
by wireman
Replied by wireman on topic Parts cross referencing
which parts are you checking?
- Old Man Rock
- Thank you received: 225
03 Jan 2012 22:38 #496172
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic Parts cross referencing
Here you go Les...
Follow the link to the kawasaki OEM parts. OEM Kawasaki Parts....
This will take you to where you click on the year.
The next few pages are for selecting street, then series (KZ900, KZ1000, kz400 etc...) then exact model.
From this you'll end up with the parts Fiche file for the specific model...
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- loudhvx
- Thank you received: 1616
03 Jan 2012 22:44 #496175
by loudhvx
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Replied by loudhvx on topic Parts cross referencing
On the KZ site, the cross reference is the little yellow question mark on the page that pops up when you click a part number. The list is not a list of bikes that part is used on, but a list of parts fiches where that number shows up. The part may or may not be used on that specific bike depending on if the fiche is used for more than one model. Usually going to the fiche of the bike in question will tell you if that part is used on that bike or not.
For example, the part may be used on a Canadian model, but not the U.S. but both use the same fiche. Or, maybe the part is used on one year, but not another, but both years use the same fiche.
Unfortuantely, you have to go and check each fiche to confirm the part is used on a particular model.
1981 KZ550 D1 gpz.
Other links.
- les holt
03 Jan 2012 22:59 #496180
by les holt
Replied by les holt on topic Parts cross referencing
Thanks guys, I came across a rear fender that resemble Z1R but are off a MK2 and I'm thinking it's the same but wanted to make sure.
Les
Les
- Thank you received: 1656
04 Jan 2012 11:10 - 18 Feb 2013 18:36 #496249
by martin_csr
Last edit: 18 Feb 2013 18:36 by martin_csr.
