Oh Wise Sage
  • TheFlyingFreemole
  • Topic Author
01 Jan 2012 23:18 #495770 by TheFlyingFreemole
Oh Wise Sage was created by TheFlyingFreemole
All the years of motorcycle experience on this site have led to useful habits and tips to follow. My problem is that I am just a greenhorn. Oh Wise MX Sages what helpful tips and habits should I try to start following from the get go with an older bike?
For example:
Kawickrice wrote: Make it a habit to turn the fuel OFF when the bike is not running. Today's bikes use vacuum and this is not a problem as much
1977 KZ1000 LTD B1 (needs minor fine tuning)
  • wireman
01 Jan 2012 23:20 #495771 by wireman
Replied by wireman on topic Oh Wise Sage
old bikes dont stop/steer as fast as new bikes! B)
01 Jan 2012 23:23 #495773 by 650ed
Replied by 650ed on topic Oh Wise Sage
When working on the bike always follow the torque recommendations shown in the Kawasaki service manual using quality torque wrenches of the appropriate scales. (i.e. don't try to use a foot pound torque wrench to tighten to inch pound settings). This will prevent you from becoming too familiar with Time-Serts or Heli-Coils. ;) Ed
02 Jan 2012 01:09 #495782 by Flyndrive
Replied by Flyndrive on topic Oh Wise Sage
When you fix things do it THE RIGHT WAY! Remember you only have two wheels and no cage.
When riding know that the people in cars do not see you, even when they look straight at you.
1980 KZ 550A1
1985 GPZ 900R
  • testarossa
02 Jan 2012 11:14 #495819 by testarossa
Replied by testarossa on topic Oh Wise Sage
Any fastener that you have not personally removed should get a shot of PBblaster 24hrs prior to actual removal. Also, make sure you have the right tools as others have stated. One thing that gets a lot of guys in trouble with their first KZ is the lack of a JIS screwdriver. JIS screws look like regular phillips heads to the un-initiated, but a phillips screwdriver will strip them out every time. You can grind the tip off a #2 phillips for use on a JIS screw in a pinch.
As for riding tips, when you are stopped at a light, keep the bike in gear with the clutch depressed, and keep an eye on your six. If a car behind you can't stop, then you will be able to ride away and not get smacked from behind. Always have an escape route planned. Make sure you get eye contact with drivers on side streets so they don't pull out because they don't see you. Stay away from any car where the driver is holding a cell phone. They are worse than drunks. At least the drunks are "trying" to get home without hitting something.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
  • andy9802gt
  • If it tastes that good, eat it yourself.
02 Jan 2012 11:22 #495821 by andy9802gt
Replied by andy9802gt on topic Oh Wise Sage
It doesn't matter if you're wearing cleaning underwear or not, the first time you get the death wobble at 130 you WILL shit your pants.
'78 KZ1075 LTD
stage 1 head by Larry Cavanaugh
race built crank by John Pearson
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
proving once again that age and treachery is better than youth and enthusiasm
02 Jan 2012 17:09 - 13 Feb 2012 18:52 #495877 by KZ250LTD
Replied by KZ250LTD on topic .
79 KZ1000ST
Past:
Many.
Last edit: 13 Feb 2012 18:52 by KZ250LTD.
02 Jan 2012 17:26 #495881 by gane
Replied by gane on topic Oh Wise Sage
Clean & Polish bike regularly. Its the easiest way to detect wear,loose fasteners,leaks,frayed cables,heated/corroded connecters et all: before they fail.G
[img][/img] 1977 KZ1000A1
  • TexasKZ
  • Away
02 Jan 2012 21:12 #495908 by TexasKZ
Replied by TexasKZ on topic Oh Wise Sage
650ed wrote: When working on the bike always follow the torque recommendations shown in the Kawasaki service manual using quality torque wrenches of the appropriate scales. (i.e. don't try to use a foot pound torque wrench to tighten to inch pound settings). This will prevent you from becoming too familiar with Time-Serts or Heli-Coils. ;) Ed
except of course the torque recommendations that are incorrect (cam caps come to mind)
02 Jan 2012 21:13 #495910 by jeffasaki
Replied by jeffasaki on topic Oh Wise Sage
DONT CRASH
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
02 Jan 2012 21:34 #495917 by 650ed
Except for the recommendations that are wrong
That's why I specified the Kawasaki Service Manual as opposed to Clymer, Haynes, or some other aftermarket manual. Obviously I can't speak for all manuals, but none of the torque specs in the KZ650 Kawasaki Service Manuals I have (3 different ones) are wrong. If there are known torque spec mistakes in the manuals for other models perhaps KZRIDER can create a forum in which to list them. Ed
02 Jan 2012 21:40 - 02 Jan 2012 21:41 #495919 by 650ed
Another tip - The screws that look like Phillips are not; they are Japanese Industrial Standard (JIS). Using Phillips screwdrivers will mess them up, but it is very easy to modify Phillips screwdriver tips to make them fit properly. See pics in link below. Ed
kzrider.com/forum/2-engine/452802-loud-c...hile-cranking#452872
Last edit: 02 Jan 2012 21:41 by 650ed.
