kz1000 from kz1000ltd
- kzc278
10 Nov 2011 16:50 #487926
by kzc278
kz650c2 1978
cb750kz 1979
xj650rj 1982
kz1000 from kz1000ltd was created by kzc278
Howdy, new to here , but not new to kzee,s. Got a nagging question i have had for years,, can a kz1000ltd be converted to a kz1000 [77-78], reason why i want to know is, visually, i much prefer the kz1000, also, the ltd,s came with the mk11 engine. Do the gas tanks swap, and most important, is the steering geometry the same..... And a completely different topic,, ever wondered why the 1000j are all gone,, burned oil badly and quickly demised,, apparently, a boring machine was out of true when kawasaki retooled..Any input on the kz1000 conversation much appreciated.
kz650c2 1978
cb750kz 1979
xj650rj 1982
- mark1122
- Keep twisting it
- Thank you received: 109
10 Nov 2011 19:01 - 10 Nov 2011 19:04 #487942
by mark1122
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Replied by mark1122 on topic kz1000 from kz1000ltd
u should not have any trouble converting a ltd to a kz. the tanks are a direct swap. i have a set of KZ rims with new rubber,if u need them. the front is the same size and the rear is bigger. 18" rather than 16". not sure if the kz has a longer shock. the rake is the same i think, but that dosent make any dif anyways.
the mk 11 is a slightly better motor. it is stronger, in some areas, crank pin , cases. more electical output .
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 10 Nov 2011 19:04 by mark1122.
The following user(s) said Thank You: kzc278
- 893cv
- Thank you received: 15
11 Nov 2011 23:20 #488114
by 893cv
1980 kz1000 LTD
1978 Z1R
Replied by 893cv on topic kz1000 from kz1000ltd
I have a 1980 KZ1000B4 that is becoming more of an A model. I will be using a 1978 police tank and an A2 seat. I am keeping the cast front wheel and will be using a later model police (18X2.5) cast rear wheel. The steering geometry will be the same with a stock A 18" rear wheel. I think the only LTDs that have the MKII engine are the 1979 & 1980 models and maby just the 1980.
I will post some photos when I am done.
1980 kz1000 LTD
1978 Z1R
- Mcdroid
- Gone Kwackers
- Thank you received: 316
12 Nov 2011 10:24 #488153
by Mcdroid
+1
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Replied by Mcdroid on topic kz1000 from kz1000ltd
893cv wrote: I think the only LTDs that have the MKII engine are the 1979 & 1980 models and maby just the 1980.
+1
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- Kapahulu
12 Nov 2011 20:03 - 12 Nov 2011 20:04 #488228
by Kapahulu
2strokeworld.com
Replied by Kapahulu on topic kz1000 from kz1000ltd
Yes I have a '79 LTD and it does not have the Mk2 motor.
Mine is mostly converted to "A" style. The front wheel was spokes when I bought it. Then I bought a spoke rear wheel along with several different KZ1000 rear axles with spacers and had to have a spacer machined to get the wheel centered in the swingarm, don't know why.
Well it will just take some time for me to swap out the wheels. My swingarm is rusty and I plan to paint it before I change the back wheel.
2strokeworld.com
Last edit: 12 Nov 2011 20:04 by Kapahulu.
