- Thank you received: 4
Trike build?
- hal0tw0
08 Oct 2011 10:47 - 08 Oct 2011 10:48 #482007
by hal0tw0
1976 KA900. VM28 pumper carbs, K&N pod fiters, RC performace 4/1 exhaust, Dyna ignition, Accel coils and wires, Ohlins rear shocks.....more to come
Trike build? was created by hal0tw0
Ive NEVER looked twice at a trike before, just not my thing. But I came across this, and although its from like 2005, ive never seen it before. I would totally like to build something like that. Its an adult big wheel on steriods! :woohoo:
What is your general thoughts on this?
www.exilecycles.com/index.php?section=25
Last edit: 08 Oct 2011 10:48 by hal0tw0.
- Thank you received: 2829
08 Oct 2011 11:19 #482009
by 650ed
Replied by 650ed on topic Trike build?
With all that rear tire and momentum trying to go straight that skinny little front tire has its work cut out for it when it's time to turn. :laugh:
- roy-b-boy-b
- Thank you received: 103
08 Oct 2011 12:38 #482024
by roy-b-boy-b
Replied by roy-b-boy-b on topic Trike build?
It is sharp! Too close to the ground. I do like the look.
The one I am trying to sell for a friend only has one wheel pulling so it is easier to manuever.
- hal0tw0
08 Oct 2011 13:39 #482029
by hal0tw0
Replied by hal0tw0 on topic Trike build?
Roy can u post more pics of that bike, especially the rear end setup? Thanks. As far as that bikes handling... We all know it wasn't built to be a canyon carver!
- roy-b-boy-b
08 Oct 2011 14:36 #482047
by roy-b-boy-b
I don't have many pictures of the rear. The bike was built so the two wheels can be removed and the rear wheel installed in less than a hour.
It had a honda 300EX axle in it.
Kenny built one that was shaft drive using a Thunderbird rear. Roy
