- Thank you received: 103
I got a Red Motorcycle
- roy-b-boy-b
26 Sep 2011 21:54 - 26 Sep 2011 21:55 #479817
by roy-b-boy-b
I just threw the Omaha part in to see if you were paying attention.
Naw, Just kidding. I am suppose to go there the first of next month to visit my Daughter. They moved there last month.
Thank you very much for the offer.
Got the bike started,then took off the carbs and cleaned them. I don't now if I want to keep this bike. I don't know if it is worth the trouble I am having to go through to get it.
I think it has a 1196 cc engine. Roy
Replied by roy-b-boy-b on topic I got a Red Motorcycle
wireman wrote: let me know when youre coming to omaha roy,plenty of room for you and bike if you need it
Last edit: 26 Sep 2011 21:55 by roy-b-boy-b.
- roy-b-boy-b
13 Oct 2011 17:38 #482983
by roy-b-boy-b
This bike has been amusing to say the least. After I got the carbs cleaned and the engine fired I had a hard time getting it in gear. I finally got it on the road and only had one gear.
I had other things to do so it sat until a few days ago when some friends came by and helped get the monster on my lift.
The shift linkage was on so it shifted backwards. After getting the shifter installed right and the slack out,the bike had all five gears.
Then I started sorting out the low voltage. The alternator was good and all I had to do was clean the connectors to make every thing right.
Then started on a oil leak. It was hard to see where the oil was comming from and had to pull the oil pan. To do this I had to pull fairing pieces,exhaust,radiator,and crash bars.
When I pulled the oil pan two bolts fell out and there was no oil pan gasket. Someone was really good with silicone.
The guy I got the bike from told me to bring it back.
It seems someone just threw the bike together good enough to get rid of it. Roy
- Thank you received: 797
13 Oct 2011 17:41 #482984
by 531blackbanshee
Replied by 531blackbanshee on topic I got a Red Motorcycle
well sure he wants it back now that you have it straightend out :lol: .
- z1kzonly
- Thank you received: 537
13 Oct 2011 23:14 #483045
by z1kzonly
Replied by z1kzonly on topic I got a Red Motorcycle
H A's in California have made the "Big Red Machine" for 25 years.
Before aftermarket bikes were even popular on cable TV shows.
Just surfin.
Hey Rusty!
Red on the head, like a dik on a dog!
Sperm banks are rejecting red headed donors!
Just surfin.
Hey Rusty!
- riverroad
- 1980 1000LTD B4
14 Oct 2011 10:10 #483137
by riverroad
Replied by riverroad on topic I got a Red Motorcycle
So you decided not to keep it? Stripped pan bolt holes, no gasket, backwards shift linkage...makes me wonder if he fixed whatever he took the pan off for correctly.
- Kidkawie
- I bleed premix
- Thank you received: 245
14 Oct 2011 12:16 #483156
by Kidkawie
Good point.
Nice bike Roy. I wonder if the ol lady would like riding on that. Kind of uncomfortable on my Z, and my ZX6R was even worse. Plus, I'm not much of a 2-up guy on a "sporty" bike.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
Replied by Kidkawie on topic I got a Red Motorcycle
riverroad wrote: So you decided not to keep it? Stripped pan bolt holes, no gasket, backwards shift linkage...makes me wonder if he fixed whatever he took the pan off for correctly.
Good point.
1975 Z1 900
2004 KX125
