40mph burnout
- badkz77
- crabtjj
- tachrev
- Rubber Side Goes Down
- Thank you received: 11
Build Thread
- garyprather
- andy9802gt
- If it tastes that good, eat it yourself.
- Thank you received: 18
'78 KZ1075 LTD
stage 1 head by Larry Cavanaugh
race built crank by John Pearson
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
proving once again that age and treachery is better than youth and enthusiasm
- wireman
- Thank you received: 299
- mtbspeedfreak
- Thank you received: 36
1105? What grind cams? RS whats? Cheng Shin rear tire? :whistle:
:laugh:
2000 ZRX 1100
1976 KZ 900- Daily Driver
- steell
- andy9802gt
'78 KZ1075 LTD
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
- nads.com
- Thank you received: 20
andy9802gt wrote: All I can say about his motor is it's 1230cc. He's running RS36's, .435 in, .410 ex.. The rear tire is a 160 metzeler on a 4.5" rim. I can't tell you lobe centers, compression ratio, the amount of headwork if any, valve sizes, horsepower or torque numbers. Not because I don't know but because he doesn't want anyone else to know.
There we go again...
CAUTION: TOP SECRET LOBE CENTERS AT WORK
DO NOT ENTER: NO WEIGHT ON REAR TIRE
People say they had a close look at the owners face.
It's a blank.
Whatever you do, don't tell us!
W will KNOWWWWW
- andy9802gt
DO NOT ENTER: NO WEIGHT ON REAR TIRE [/quote]
You're right there's no weight on the back tire. Must be why most drag bikes run some type of stretched arm so they can lose traction. That explains my friends busa with a 12" over that runs 8.6-8.8 1/4's @ 160 plus on street tires, maybe if he went 6" over and got some traction back he could get in the 7's. What top secret stuff did you do to your motor NADS to keep it from running? Was it maybe hogging out the ports with a 3/8" burr bit? Or was it the little wimpy .285 cams? While it may not be impressive to some I think it's pretty good. So NADS, in conclusion, Put your helmet on and take that retarded shit down the road.
'78 KZ1075 LTD
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
- badkz77
1977 KZ1000A1
