Hard to find parts ?
- otakar
17 Jun 2011 08:34 - 17 Jun 2011 09:06 #457744
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Replied by otakar on topic Hard to find parts ?
My CCT is still OE and I have over 60K on one of my bikes. The first thing to go on these things are the coils actually. All three of mine went bad. Also my pulsing coils went out twice and my stater has burned out three times. My water pump seal was replaced twice and so has my radiator. Parts for 1300s can now usually be only found from second hand sources like eBay. I have been hoarding parts for years. Some parts are next to impossible to find, such as rear master cylinder parts. The front Master cylinder parts are available as long as the sleeve is not rusted. However that one can be replaced with a new unit for about $100. Body parts are strictly eBay hunts.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 17 Jun 2011 09:06 by otakar.
- Thank you received: 1656
17 Jun 2011 10:04 - 14 Feb 2013 11:24 #457755
by martin_csr
Last edit: 14 Feb 2013 11:24 by martin_csr.
- otakar
17 Jun 2011 11:50 #457764
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
There are quite a few coils that will work but fitting is a problem. This system is an oddity by Kawasaki. It is a 3 Ohm IC ignition. Unlike the others that are 2.2 Ohm The only ones I know of that are REALLY good are Nology PFC-30D and MSD 4573
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- wildman1138
17 Jun 2011 13:54 #457781
by wildman1138
old kaws dont die , they just go faster
Replied by wildman1138 on topic Hard to find parts ?
I already installed a zx-11 cct , I paid 7 bucks for it from a guy on craigslist that wrecked his . It only had like 15k on the clock ,and it looks like a new one . I did that upon taking it out of storage at my father in laws house . I fugured it was time to take this project off the back burner . I love the way this thing sounds .
- wildman1138
17 Jun 2011 13:58 #457783
by wildman1138
also as far as ignition , I plan to find two DYNA-S units for the small fours and installinf three pick ups on one plate to make a good quality ignition .. no more hunting an obsolete igniter that goes for 300 bucks at best . I already have one dyna s from my 650 . the backing plate mounts the same way and I have already made all the holes in it to line up the pick ups . so far so good ...
- otakar
18 Jun 2011 10:33 - 18 Jun 2011 10:35 #457985
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Sorry I couldn't talk last night, but my wife and I don't get to go out much. The Dynna S is only a good replacement for points. It is a substandard ignition to the Kawasaki OE ignition. The KZ1300 ignition is much superior to the Dyna. I have not had a IC module go bad on these yet and it is not a common problem. The pickups go bad but the module is good. The pickups can be used from other KZ plates. I plan on building my own Hi-Performance module out of three GM modules and use the Kawasaki pickup plate to control them. The Coils are the week link in the ignition.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 18 Jun 2011 10:35 by otakar.
- otakar
18 Jun 2011 10:44 #457986
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
No eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configurationHere are some of the airbox components you were looking for.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- otakar
18 Jun 2011 11:03 #457987
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
You also have this choice.
www.kz1300.com/parts/pod-filters.html
There is some carburetor modification and some clever pod remolding required but I love these.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
