Will This Work??
- stablechaser35
07 Jun 2011 23:51 - 07 Jun 2011 23:55 #456045
by stablechaser35
"Not as good as I once was, but as good once as I ever was"... yeah right... don't have the back for that, I was AMAZING when I was younger, now I'm just here...
Will This Work?? was created by stablechaser35
shop.bevelheaven.com/detail.aspx?ID=206
I have a '78 KZ1000... not sure beyond that, I know it has more modern carbs and the electrical has been rigged and then rerigged due to the one-way clutch not being good anymore, I have to kickstart it currently... electric start is bypassed and a few other things are "not stock", shall we say... the front brake master cylinder is jacked beyond belief... any thoughts on whether or not this would work on my bike... I'm clueless and desperate at this point... sigh, lol
Last edit: 07 Jun 2011 23:55 by stablechaser35.
- elfmagic17
- Thank you received: 24
08 Jun 2011 00:04 #456047
by elfmagic17
Kenny Hicks
74 Honda CB550
Replied by elfmagic17 on topic Will This Work??
It will work but if you have single caliper it is kinda overkill. Have you tried Z1enterprizes or Dennis Kirk? May be a little less pricey.
Kenny Hicks
74 Honda CB550
The following user(s) said Thank You: stablechaser35
- stablechaser35
08 Jun 2011 00:20 #456050
by stablechaser35
Have had the bike about a week... slowly discovering everything it needs... this is just one of the more obvious things I've found so far... have been informed by my mechanic (the guy that does the serious stuff that I'm sure I would fubar) that the "one way clutch"?? is bad... I think I know what part of the engine it's in, but couldn't draw it to save my life, if that makes sense... I'm learning all over again after a 15+ year absense from riding... thanks for the help, will check those right now
Replied by stablechaser35 on topic Will This Work??
elfmagic17 wrote: It will work but if you have single caliper it is kinda overkill. Have you tried Z1enterprizes or Dennis Kirk? May be a little less pricey.
- wireman
- Thank you received: 299
08 Jun 2011 04:40 #456082
by wireman
Replied by wireman on topic Will This Work??
stock master cylinder for 78 1000 with single disc on front is actually 13mm i do believe,12mm will take a little more pulling to get job done.
although im one of the few who actually has no problem with running the 13mm master cylinder with dual discs
