Killer RPM while cruising?
- miles
24 May 2011 19:09 #453324
by miles
Killer RPM while cruising? was created by miles
Hello to all. I recently dug out my moms original 1978 KZ 400B1 with 5K miles on it. Had the carbs worked got a new battery and replaced the rectifier, all the blown lightbulbs, a missing gas cap and I'm still looking for a headlight. The bike has been sitting since 1991 so I put in new plugs cleaned the tank changed the oil and lubed the chain.
I took the bike for a cruise down the road and it seems the rpm is around 6500 at 70mph. Next time I take it for a ride I will note the exact rpm and speed. My question is.... will it hurt the bike to run that high of an rpm for an extended anount of time? We are getting ready for a 600 mile round trip.
- moneypit
- Thank you received: 35
24 May 2011 19:58 #453329
by moneypit
2-76 kz900
St Paul MN
Replied by moneypit on topic Killer RPM while cruising?
That sounds about right to me although I own a 900. Also make sure your tires arent cracked, that can kill you!
2-76 kz900
St Paul MN
- Thank you received: 2829
24 May 2011 20:53 - 24 May 2011 20:54 #453342
by 650ed
Replied by 650ed on topic Killer RPM while cruising?
Hopefully someone with a KZ400 will chime in, but that sounds high to me. Are you sure your clutch isn't slipping? On my KZ650-C1 4,500 rpm = 60 mph; 6,000 rpm = 80 mph. If you look in the front of the Kawasaki factory service manual you should find a graph that may help. Ed
Last edit: 24 May 2011 20:54 by 650ed.
- Thank you received: 2098
24 May 2011 22:57 - 24 May 2011 22:58 #453381
by Patton
Replied by Patton on topic Killer RPM while cruising?
Likely find some comparisons regarding highway cruising rpm in the following site.
Click > www.armbell.com/forum/index.php?c=6&sid=...571a51a&mforum=kz400
Last edit: 24 May 2011 22:58 by Patton.
