- Thank you received: 133
Warm up procedure?
- Topper
Getting it to that point is a real bear though and I wonder if I'm doing something wrong. I'm new to motorcycling, wrenching and old bikes. So total noob here.
If the air temp is below 70 degrees F I put it on full choke, no throttle and it starts right up. The idle climbs up above 2000 pretty quickly and I start moving the choke down little by little.
It's really sensative at this point. If I let the idle fall below 1500 it'll quickly drop and stall.
It takes a minute or two but eventually I have the choke off and it's just barely staying running. In fact it'll usually stall on me at the first couple of stops.
After a few miles it seems to warm up and then runs fine. The idle is nice and stable right around 1100.
I've adjusted the air mix screws and idle set screw according to Tek9ine's very sound advice, which is what got me this far. It runs great when warm or when the air temp is above 70. Any colder and it's almost impossible to get going.
Am I doing something wrong or does my bike need some sort of adjustment?
Permanent and perpetual noob.
1979 KZ750 Twin
2009 Kawasaki Versys
- RetroRiceRocketRider
- Thank you received: 29
Each of us have our own "start up procedure" that we use. As long as it gets your bike running without damage or extreme effort and in a decent amount of time, then you're all good.
- KZQ
- Administrator
- Thank you received: 1409
Bill
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
- Topper
1979 KZ750 Twin
- JR
- Thank you received: 445
- KZQ
- Administrator
Topper wrote: So I've been tempted to adjust the idle stop screw to keep it from stalling before its warm. Bad idea or is that ok?
That's a good strategy. After you've been riding a while you'll notice the high idle at a stop light and can easily turn it back.
Bill
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
- RonKZ650
- Thank you received: 240
- Topper
1979 KZ750 Twin
- TeK9iNe
- What did you do!?!
- Thank you received: 28
I've never had to ride a bike with the choke on that was tuned properly, but I always get the choke off quickly, and I can attribute this to a very good vacuum synchronization.
If you perform a vacuum sync, the bike wont stall when you go off choke. I can turn mine off right after I go to half choke for 10 seconds, then she will still idle at about 600-700rpm just fine and smooth. Wait till she comes up to regular idle (a minute), and then pull away.
To each there own, but a bike shouldnt be stalling, less you're really impatient, and if so, invest in some goood oil :laugh:
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- H1Vindicator
- Thank you received: 47
- Motor Head
- Thank you received: 391
- Topper
Could that be a sign I need further pilot jet changes?
1979 KZ750 Twin
