- Thank you received: 15
Ultra Sonic carb cleaner- who's got 'em, how much,
- CruisingRam
04 May 2011 17:53 #448891
by CruisingRam
1975 Z1 B 900- soon to be heavily modded
Pahoa, Hawaii is my new hom
I am working hard to save up the shipping money to get my shop opened here in Hawaii
I hate electrical stuff.
Ultra Sonic carb cleaner- who's got 'em, how much, was created by CruisingRam
and so on and so on- I need to get one here I think, and I need to get one of these I think?
- TeK9iNe
- What did you do!?!
- Thank you received: 28
04 May 2011 19:15 #448898
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic Ultra Sonic carb cleaner- who's got 'em, how much,
You dont need an ultrasonic unless you're starting up a business.
A good dip with a back massager taped to the drum works very well.
Then just be sure to blow through all the jets/orifaces.
If you are starting a business, well...
www.ultrasonicleaners.com/
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- CruisingRam
04 May 2011 20:19 #448909
by CruisingRam
Replied by CruisingRam on topic Ultra Sonic carb cleaner- who's got 'em, how much,
www.harborfreight.com/25-liter-ultrasonic-cleaner-95563.html
Anyone use this one? I will have a shop again soon, and I saw one, smallish, but not this brand, that a shop owner in Missouri had, and man, it was great! I just need to do one carb at a time- don't need a huge basket
- otakar
04 May 2011 20:24 #448913
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Replied by otakar on topic Ultra Sonic carb cleaner- who's got 'em, how much,
I have one and I love it. You can not put solvent directly into it. You must have a tank within a tank. Water goes into the main and solvent into the inner.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- CruisingRam
04 May 2011 20:40 #448918
by CruisingRam
What model you have? Do you have pictures of your set up?
otakar wrote: I have one and I love it. You can not put solvent directly into it. You must have a tank within a tank. Water goes into the main and solvent into the inner.
- otakar
04 May 2011 21:02 #448926
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Mine I can just put individual carbs into so I have to take the racks apart. I have the McMaster Carr 3410K82 unit 55W $400
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- testarossa
- Thank you received: 82
05 May 2011 09:03 #449008
by testarossa
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
Replied by testarossa on topic Ultra Sonic carb cleaner- who's got 'em, how much,
I have a small Branson unit that will fit one carb body at at time like Otakar. Works well for my purposes. I mentioned it in a thread about a year ago:
Click me to go Ultrasonic!
We recently got a slightly larger Branson 2510 at work. It's nice because it has a built in heater, and cycle timer so you can just set it and walk away. This unit is large enough to fit two carbs at a time.
One pointer is to make sure you get a basket that fits your tank, or suspend your parts some other way. You are not supposed to set parts on the bottom of the tank. Also, I don't know what's in Branson's cleaner chemical but it works well on cutting oil. I haven't tried a carb in there yet.
2004 ZX-10R
Angola, IN
- otakar
05 May 2011 09:20 #449010
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Mine also has a heater and a timer. I have done a lot of injectors in it along with some carb bodies. I use mostly the ZEP Citrus Cleaner as a solvent with a bit of Butyl Ether added. This makes the cleaning solution water miscible and removes the varnish off the carb bodies, also with most to all paint. I have cleaned a lot of model airplane engines in it and those get caked up with a tremendous amount of backed on varnish from the Castor oil we use as a lubricant.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
