Billet parts and swingarms
  • rslingshot
  • rslingshot's Avatar Topic Author
24 Apr 2011 12:41
#446724
What billet parts would you like to be able to get for the KZ 900/1000'S. And what swingarm set up would you like monoshock,dual shock, stock tire size 180,190? Let me know I get alot of emails asking for parts and swingarms so before I do anything I would like ask what do people really want and see if it is worth getting into.
  • otakar
  • otakar's Avatar
Re: Billet parts and swingarms
24 Apr 2011 12:46
#446727
I would love to see adapter plates for different forks and brake calipers.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
  • rslingshot
24 Apr 2011 12:50
#446728
otakar wrote: I would love to see adapter plates for different forks and brake calipers.
Good idea, so you can run updated brakes on the older forks
  • trianglelaguna
  • trianglelaguna's Avatar
24 Apr 2011 13:20
#446733
great idea on the caliper hangers....wonder if any of the big four shared two pot binders 2005---forward....
fork braces, stock dia
motor mount kits.....
frame brace kits.....
140-150 dual shock braced arms from a stock arm upside down caliper mounts...and three position shock sets
aluminum swing arms dual shock 140-150 mm tires...eccentric axles and cal fab or jmc style......
oil cooler kits with lines...
spacer kits to run three spoke CBR F-4 rims in the stcok forks and swingarms....
knurled passenger pegs to match the tarrozi rear sets
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
  • Old Man Rock
  • Old Man Rock's Avatar
24 Apr 2011 14:31
#446755
Oh now it's a good idea aye? :laugh: :laugh: :laugh:
Dual shock up to 180 tire would be my best guess for not everyone has the tools, space, skills for Mono mounts. With pivot tube exact width as KZ, even the average Joe can install this setup in a weekend.
Two options as I see it... Dual shocks in either case....
1) Stock arm lengths for stock spoke rim and tire sizes. No chain change required. Will fit existing brake systems (drum/Disk) pending model. GS1100 theme! ;)
2) Possibly 2" over for the mods with 180 tires... Obviously brake, spacers, chain etc... would require updates by the owner.
I believe number (1) will be your biggest hit if reasonably priced...
Just my two worthless cents....
Good luck and keep us posted no doubt!....
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
24 Apr 2011 16:18 - 24 Apr 2011 16:20
#446781
how about a points cover. i like the ones Yosh makes . they have a bevel on the bottom half, and a Yosh logo/signature on the top. i would suggest u come up with a cool sig. maybe a generic kawi , that way these covers may fit dif modles? or it could be more spacific like Z1 or KZ, or maybe your brass knuckle sig. ?
i love your new motormounts , and kicker block off too.
You could do brake res caps with logos/sigs too.
a lot of guys would need bar risers for there new front ends.and guage and headlight holders.
Just throwing out ideas. Hope it helps.
M
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 24 Apr 2011 16:20 by mark1122.
  • Old Man Rock
24 Apr 2011 16:34
#446784
Rear-sets....;)
Ones that direct fit, brake pedal/kick start not affected.
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
  • racer54
  • racer54's Avatar
24 Apr 2011 17:30
#446794
Extended arm up to 8" over for up to 200mm tires, dual shocks with multiple shock mounting.
Extended arm 2" over with dual shocks mounting 180 tires with multiple shock mounting options
Trees to mount modern forks
plates to mount newer brakes on stock forks
Extended arms to 8" over mono-shock...along with top shock mounting bracket...as close to a kit to mount mono-shock as possible
