- Thank you received: 1
How many miles when you switch to reserve?
- Mike Mecredy
19 Apr 2011 11:38 #445530
by Mike Mecredy
1997 KZ1000 police
How many miles when you switch to reserve? was created by Mike Mecredy
My bike's a '97 KZ 1000P and I have to switch to reserve at about 95 -100 mile on a fill up. But then I top off the tank and it only takes a bout 2.5 gallons. With the tank holding around 4 gallons do I still have a gallon and a half when I switch to reserve? It seems a bit much to me.
1997 KZ1000 police
- DoubleDub
- Visitor
19 Apr 2011 11:58 #445534
by DoubleDub
Replied by DoubleDub on topic How many miles when you switch to reserve?
Sounds excessively early.
I would take the gas tank off and clean out the area around the petcock to ensure it's not getting plugged with rust/sediment causing premature reserve.
As for how many miles, that depends greatly on your gas mileage (of course).
- Thank you received: 1656
19 Apr 2011 12:03 - 13 Feb 2013 12:55 #445537
by martin_csr
Last edit: 13 Feb 2013 12:55 by martin_csr.
- Motor Head
- Thank you received: 391
19 Apr 2011 14:36 - 19 Apr 2011 16:51 #445584
by Motor Head
Replied by Motor Head on topic How many miles when you switch to reserve?
Some trim down the fuel pipe on the petcock inlet, remove from tank and look how tall it is. Me I ride on RES all the time, keeping track of miles traveled and where the gauge is registering. You should be in the 40-45 MPG range with stock bike and gearing, so 4 gallons should go 160 miles on the open road. I've gone 183 on my 1000 LTD with a 1 tooth larger counter-shaft sprocket, 16 as apposed to 15, 630 chain. But that gauge was bottomed for quite awhile, :whistle:
Last edit: 19 Apr 2011 16:51 by Motor Head. Reason: screwed up yet again.
- djturnz
- Thank you received: 5
28 Apr 2011 08:53 #447513
by djturnz
1982 KZ750 (4) LTD
Replied by djturnz on topic How many miles when you switch to reserve?
It starts to sputter around 80-90 miles and then reserve gets me to about 110 or so empty (found that out the hard way once).
I may have to try it again while taking extra gas with me.
1982 KZ750 (4) LTD
- Mike Mecredy
05 May 2011 21:55 #449123
by Mike Mecredy
1997 KZ1000 police
Replied by Mike Mecredy on topic How many miles when you switch to reserve?
Yesterday, I looked down and my trip odometer was reading 105 miles. I always reset it to zero when I fill up. Well I thought maybe I'd left it on reserve but I hadn't. Usually I have to turn the valve way before 105 miles. A few days before the last fill up I changed my air cleaner and just doing that gave me 105 miles on only 2.46 gallons. I guess that made a big difference.
1997 KZ1000 police
