- Thank you received: 3
Will stainless steel rust if on an exhaust header?
- 9am53
- homebrew, and some bbq
29 Mar 2011 19:23 #441269
by 9am53
'84 GPz900r
'71 CB350
s289.photobucket.com/albums/ll231/9am53/
Will stainless steel rust if on an exhaust header? was created by 9am53
I know some of you are thinking "is he retarded? it's stainless" I am not retarded, stainless rusts to shit real quick under certain conditions, I am just wondering if high heat is one of them. I blasted and BBQ painted the heat shields on my KLR and want to replace the rusty bolts that hold the shields on with stainless, then shoot some BBQ paint on the bolt heads once they are on to make them black. Anybody tried something like this?
'84 GPz900r
'71 CB350
- hal0tw0
- Thank you received: 4
29 Mar 2011 20:52 #441293
by hal0tw0
1976 KA900. VM28 pumper carbs, K&N pod fiters, RC performace 4/1 exhaust, Dyna ignition, Accel coils and wires, Ohlins rear shocks.....more to come
Replied by hal0tw0 on topic Will stainless steel rust if on an exhaust header?
I believe the corrosion will occur with dissimilar metals contacting each other under the right conditions (heat, humidity, etc.). Stainless on stainless should be ok.
- 9am53
29 Mar 2011 20:53 #441294
by 9am53
'84 GPz900r
'71 CB350
Replied by 9am53 on topic Will stainless steel rust if on an exhaust header?
It was going to be stainless on steel...
'84 GPz900r
'71 CB350
- TeK9iNe
- What did you do!?!
- Thank you received: 28
29 Mar 2011 21:07 #441296
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic Will stainless steel rust if on an exhaust header?
No, your stainless wont rust
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- T_Dub
- Thank you received: 25
29 Mar 2011 21:10 #441297
by T_Dub
1977 KZ650B1
-810cc
-Cavanaugh Racing Head
-Mikuni RS34's
-GPR Muffler
Replied by T_Dub on topic Will stainless steel rust if on an exhaust header?
Your steel should rust in that situation, but since its a big exhaust and a small bolt, the exhaust should be fine, very little potential there.
1977 KZ650B1
-810cc
-Mikuni RS34's
-GPR Muffler
- KZQ
- Administrator
- Thank you received: 1409
29 Mar 2011 21:45 #441316
by KZQ
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Replied by KZQ on topic Will stainless steel rust if on an exhaust header?
I've seen plenty of stainless threaded rod rust. I guess it depends on the grade. If I ever build a stainless cable railing again I'll make it a very stupidasole proof part of the contract.
Bill
Bill
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
