- Thank you received: 240
Another reason to use correct tires
- RonKZ650
- wireman
- Thank you received: 299
- trianglelaguna
- Thank you received: 235
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
- Jeff.Saunders
The factory had tire choices and for the most part select the best tire sizes for the bike.
On bikes like the 650's, 900's and 1000's with 19" front and 18" rear the stock bikes are very well balanced going into turns.
Putting an oversized rear tire on the bike will cause it to dive into corners.
Tire technology has improved, but the rake and trail of these old classics benefit from a ribbed or semi-ribbed tire on the front. You MUST stick with bias-ply tires. Radial tires are designed for bikes with very different steering geometry.
I personally try to stick with the same brand/series tire front and back. I've ridden some bikes with mismatches and wasn't happy with the results.
www.z1enterprises.com
Z1 Ent on Facebook,
- wireman
or are we going to be forced to buy the latest offerings from cheng-shin ?
the main reason i hear from people switching to 17" tires/wheels is because its very hard to find decent 18 and 19" tires.
- kawman14733
- Jeff.Saunders
is there any kind of comitment from tire manufacturers to continue making good tires to fit these bikes are are we going to be forced to hunt down tires that have been collecting dust in a warehouse/shelf for 10 years?
There's a lot more tires being made that you see in most of the catalogs. Out of Japan there's Dunlop tires - K87 rear F11 front and TT100's in front and rear. These are all newly made. The distributors/importers are the issue, they choose not to import these tires.
We don't typically bring them in as the price of 1 or 2 at a time is way too high. It would be about $200 for a rear TT100 - about double what most people are willing to pay.
Even if we brought 50 in of each at a time, the prices don't drop much, it would still be around $180 for a TT100 rear... ouch.
Z1 Ent on Facebook,
- trianglelaguna
1976 KZ900
2003 ZX12R
2007 FZ1000
