- Thank you received: 12
my friend and old school wrench in Singapore - Yee
- WPBill
01 Mar 2011 05:16 #434137
by WPBill
You can only be young once, but you can be immature forever!
Kamakura JAPAN, 1975 Z1B (x2, both in storage)
my friend and old school wrench in Singapore - Yee was created by WPBill
While I was stationed in Singapore 2000 - 2002, I would take my HD to SUNBURST for repairs and mods instead of to the HD dealership. Yee is the owner/mechanic and he is definitely an old school mechanic. Shipping costs make picking/choosing from catalogs very expensive, so pretty much anything that is not HD specific he makes from locally available items.
Here are some pix I took when I visited his shop while I was in Singapore a couple weeks ago.
The Government of Singapore makes is prohibitively expensive to own a bike or car more than ten years after the manufacture date, so most of the bikes in his shop are newer HDs. Yee doesn't consider himself a HD only guy, just that most of his customers are HD owners.
The man himself
Token KZRider qualifying bike
CB350 Four based cafe racer which Yee put together
old style fire extinguisher welded to HD. Yee says that was a popular mod on old Triumphs.
here's a good example of making do with local stuff. The fuel petcock is a LPG gas line valve "liberated" from a food hawker stall. Yee bent all the copper lines himself. He used to make his own oil tanks by welding two fire extinguishers together, but he says these days its actually pretty easy to get an aftermarket tank in Singapore. All he does is to plumb in a valve to facilitate draining the tank. The air cleaner is from a car, and took some work to mate to the Keihin (IIRC) carb on the bike. Heater ducting is what he used to make the exhaust heat shields. The last picture is kind of hard to see, but what he did was to reduce the wiring size for most of the loom so he could run the wiring through the frame and clean things up.
The man himself
- WPBill
01 Mar 2011 05:18 #434138
by WPBill
Replied by WPBill on topic my friend and old school wrench in Singapore - Yee
Here's a V-Rod he worked on. The big mod is moving the gauge cluster off the handlebars and into a mounting he faired into the faux tank
said it took a lot of measuring and calculating to get both the look and enough handlebar clearance at full lock
aluminum endcap he fabbed for swingarm mount to hide the large nut, normally exposed
his shop
his shop
- TeK9iNe
- What did you do!?!
- Thank you received: 28
01 Mar 2011 05:50 #434141
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic my friend and old school wrench in Singapore - Yee
:laugh: The mother of invention is need! :laugh:
Good stuff!
Good stuff!
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- Thank you received: 797
01 Mar 2011 06:18 #434148
by 531blackbanshee
Replied by 531blackbanshee on topic my friend and old school wrench in Singapore - Yee
:ohmy:
the z1r!
amazing how innovative people can be.
the z1r!
