engine serial number
- zedted
27 Feb 2011 23:15 #433906
by zedted
engine serial number was created by zedted
Anyone of you ever saw a z1 up to z1000A engine block where the serial number was not stamped on the flat area behind the cilinder, on top of the clutch compartment?
Well, I did, needed spares and bought the engine but did not find/ locate (yet) the serial number however the stamping on the barrels (bottom, front side right) show 1015L so a z1000A1/A2
There is simply no flat area on the spot I mentioned above. Will try and mae a picture.
- Thank you received: 2098
27 Feb 2011 23:33 - 27 Feb 2011 23:34 #433908
by Patton
Replied by Patton on topic engine serial number
Not positive, but thinking that Kawasaki motorcycle frames and crank cases obtained from KHI as replacement parts might not have had numbers.
Last edit: 27 Feb 2011 23:34 by Patton.
- Mcdroid
- Gone Kwackers
- Thank you received: 316
28 Feb 2011 02:45 #433912
by Mcdroid
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Replied by Mcdroid on topic engine serial number
Patton wrote:
So ZedTed, there was not even a raised 'platform' area with a blank field? This area is cast into cases, even blank ones. As for cases w/no numbers, they come from Kawasaki that way in warranty issues (I speak from a position of strength). In the past, if you had blank cases, motor VIN's were reassigned by each state's DMV.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- zedted
28 Feb 2011 03:22 #433913
by zedted
Replied by zedted on topic engine serial number
No, correct, not even a raised flattened (casted) platform.
Let me make a picture and you'll see
rtegards,
Ted
rtegards,
Ted
- z1kzonly
- Thank you received: 538
28 Feb 2011 20:20 #434097
by z1kzonly
Replied by z1kzonly on topic engine serial number
It's called a file! Someone filed down the original numbers!
Over the years, people have switched engines, sold engines, stole, insurance jobs, and traded them back and forth.
I have been there 12 or so different times!
Z1F, Z1E, KZT00A
Just like the 1st year of Z1, there was no lip on the engine
# then they realized that anyone could file down the # block and stamp any other # into it.
Next, ther factory put that little lip around the engine #'s. Making it haed to stamp new #'s into the case!
The factory used standard 1/4" stamps !
ISO before ISO was invented! Standard size #'s.
WTF???
Z1F, Z1E, KZT00A
WTF???
- zedted
07 Mar 2011 22:13 #436070
by zedted
- Mcdroid
- Gone Kwackers
08 Mar 2011 00:03 #436078
by Mcdroid
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Now that is interesting...I have never seen a Z1/Z900/Z1000 case without the precast VIN platform. There doesn't appear to be a grinding marks for removing it...and why would you go to all that trouble (although it is possible to do as the platform is a solid casting and would grind completely off without opening into the case)?. Well, KZ1000 A/B cases have the oil capacity embossed on top of the cases next to the oil opening. Z1 cases do not...that case does not have the embossed oil capacity, so I'm guessing a Z1 case that someone has altered. :S
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- Jeff.Saunders
08 Mar 2011 05:58 #436104
by Jeff.Saunders
This email address is being protected from spambots. You need JavaScript enabled to view it.
www.z1enterprises.com
Z1 Ent on Facebook,
Replied by Jeff.Saunders on topic engine serial number
Can you take some more pictures of the cases - the front, etc. Does it have the words kick starter cast into the cases over the kick starter area?
I am very curious about these. One of our customers and a tremendous Z1 enthusiast has a collection of early Z1's - including some of the prototype V1 bikes. ALL of those engines have engine numbers.
Kawasaki did product replacement cases. I owned a set a few years ago - but they had the raised area where the number would be stamped.
Z1 Ent on Facebook,
- Mellvis
08 Mar 2011 14:23 #436227
by Mellvis
Replied by Mellvis on topic engine serial number
Could these possibly be for training purposes in tech schools, or something of that nature? In school we had several Honda motorcycles and engines that had NO numbers at all. The serial number area was plainly stamped "FOR TRAINING ONLY". When we disposed of them, every piece had to be destroyed beyond use. We had to cut every spoke and every wire. It was hard cutting up 2 CBXs with less than 3 miles on them. We cut up a Turbo 650 (the one built on the CX500 engine platform) and a spare drive train for the turbo bike. I think there were 20 of the CM400 HondaMatics. It was a rough week at school.
