- Thank you received: 3
to buy or not?
- hardr0ck68
- Who put the what in the where?
15 Feb 2011 16:38 #430919
by hardr0ck68
1977 kz650 c1
bought it because I was told it would never run again...I like to prove people wrong.
to buy or not? was created by hardr0ck68
Ok, so I have a line on a new to me bike. It is a 1979 kz1000 the guy is asking $300, but he really just want's it gone. It is a basket case, but supposedly all there except for some bits that the PO was going to replace, like the spokes, which were cut. He says the motor and frame were sand blasted (the motor was blasted assembled, and I know that is dangerous). The frame is in primer.
So what do you all think? I don't really want to part out a bike that I don't need parts from for one of my projects (I would really like to part out a 1990 zx750)... but with spring around the corner, I am thinking of buying it piecing it back together and flipping is, but if something as simple as the coils are missing or shot the price of the rebuild could quickly surpass the cost of rebuilding it.
SO what do you all think? I am on the fence here (I just bought a Winchester model 70 in 300 win-mag and I am about out of play money).
1977 kz650 c1
- TerryK
15 Feb 2011 16:57 #430923
by TerryK
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
Replied by TerryK on topic to buy or not?
You crazy? Buy it! Could be a build, lots of spares or part out. Either way, offer him $200.00 and if you don't use it right away just sit on it until you decide what to do with it.
1977 KZ1000
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
- racer54
- Thank you received: 114
15 Feb 2011 16:58 #430924
by racer54
Replied by racer54 on topic to buy or not?
I'd do it! Even though you don't want to, you can piece it out if all else fails but you can take your time to find and buy any parts you find you need. This way you won't end up paying too high a price for them. Time is on your side with this one.
- hardr0ck68
15 Feb 2011 18:33 #430966
by hardr0ck68
1977 kz650 c1
Replied by hardr0ck68 on topic to buy or not?
Ha, one thing I forgot to point out, time is not on my side. Either way (parted or built) it would need to be gone come spring. I currently live in an apartment, my workspace is in my livingroom
If I build it I would feel the need to add new brake lines (100), chain and sprockets (100), and at least change the fluid in the forks... it would also either need a set of rims or new spokes and turing(100). I could rattle can the paint when the weather breaks up here.
If I get lucky and get away with building it for like $500 + $200 to buy it, what will I get for it in Spring? $1,000?
1977 kz650 c1
- steell
16 Feb 2011 06:59 #431033
by steell
Replied by steell on topic to buy or not?
Every time I buy a used bike, even a complete and running bike, it still usually costs me over $1000 to bring it up to standards.
Then there's my ingrained dislike of leaving any bike stock.
Case in point, currently I have a ZX11 that I bought recently, and it "only needed carbs cleaned". New bodywork, new Kandy Burple paint, new smoke windshield, new tires, convert to Zx9 wheels, convert to coil on plug, convert to EFI, replace exhaust system with Muzzy Titanium, and I'm determined to have it done by May 15th.
I'd have 5 years and $10,000 in a bike in the box :woohoo:
That's why I have close to $4,000 into a 79 750 twin that might bring $1500 on a good day. :dry:
Just can't help it.
Just can't help it.
- DoubleDub
- Visitor
16 Feb 2011 07:20 #431041
by DoubleDub
Replied by DoubleDub on topic to buy or not?
If you don't buy it, help a brother out who's looking for another project. Friends don't let friends not buy $300 Kz1000's....
- RonKZ650
- Thank you received: 240
16 Feb 2011 07:35 #431044
by RonKZ650
Replied by RonKZ650 on topic to buy or not?
One thing, there were no spokes used on KZ1000s in 1979 so most likely it's a 1978 or earlier. Can't go too wrong at $300 either way.
- Jack
- Thank you received: 7
16 Feb 2011 07:37 #431045
by Jack
79 KZ 1075 MKll
79 KZ 1500 MKll dragbike
Gone but not forgotten:
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
Replied by Jack on topic to buy or not?
If it's a 79 MKll the crankcases alone are worth the $300 and you can get that and more for the crank...
79 KZ 1075 MKll
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
- Thank you received: 1656
16 Feb 2011 07:41 - 11 Feb 2013 12:40 #431047
by martin_csr
Last edit: 11 Feb 2013 12:40 by martin_csr.
- kawsakiman
- Thank you received: 6
16 Feb 2011 10:50 #431064
by kawsakiman
Replied by kawsakiman on topic to buy or not?
i have mag wheels for you rocco if you ever get back to ny.
sorry, i just can't resist.
buy it, build it.
more go fast parts for a 1000 than a 650. :woohoo:
buy it, build it.
- hardr0ck68
16 Feb 2011 14:11 #431100
by hardr0ck68
1977 kz650 c1
With the KZX800 project moving forward (slowly) I honestly don't need another money pit bike for myself.
But I think I will call him back on payday. I might as well buy it and see what it needs, worse case I can part it and come out with some extra $$.
1977 kz650 c1
- dejavoodo41
- Thank you received: 14
16 Feb 2011 19:16 #431173
by dejavoodo41
1977 KZ1000A With 1980 KZ1000A MKII engine, Wiseco 1105 kit, Dyna S Ignition, 3 Ohm Dyna Coils, Cams, Mikuni RS34 Carbs, Vance and Hines Pro Pipe with Comp Baffle
New Smyrna Beach, FL
Replied by dejavoodo41 on topic to buy or not?
I'd defiantly buy it. Hell it's going to cost me $300 to fix my clutch fiasco.
