motorcycle lift. only on frame or engine ok?
- Beard
12 Feb 2011 10:39 #430205
by Beard
79 KZ650B
Jack of everything, Master of nothing.
motorcycle lift. only on frame or engine ok? was created by Beard
Just wondering..I picked up one of those harbor frieght motorcycle lifts.. im totally satisfied on the stability of it.. but im only lifting a sub 400lb kz650..
my question is:
should i make up some spacer blocks it lift the bike using 4 points on the frame.. or is it ok for the lift to be raising the bike via touching the motor/trans?
didnt know if that puts alot of stress on motor mounts or what
thanks for your opinion
my question is:
79 KZ650B
- TeK9iNe
- What did you do!?!
- Thank you received: 28
12 Feb 2011 10:45 #430206
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic motorcycle lift. only on frame or engine ok?
Lifting the bike by the engine is ok, but not recommended for stability, or access.
I would probly make up some wood "shims" to use the fram as lift point and then have access to removing the engine if I like.
Peace.
Peace.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- dejavoodo41
- Thank you received: 14
12 Feb 2011 15:35 #430260
by dejavoodo41
1977 KZ1000A With 1980 KZ1000A MKII engine, Wiseco 1105 kit, Dyna S Ignition, 3 Ohm Dyna Coils, Cams, Mikuni RS34 Carbs, Vance and Hines Pro Pipe with Comp Baffle
New Smyrna Beach, FL
Replied by dejavoodo41 on topic motorcycle lift. only on frame or engine ok?
I have one of the Harbor Freight lifts and usually I just have play with the positioning a bit and can usually find the sweet spot. It actually works pretty well for most tasks
- steell
12 Feb 2011 17:06 #430284
by steell
Replied by steell on topic motorcycle lift. only on frame or engine ok?
Beard wrote:
Sub 400 lb KZ650????
WOW! How did you get it so light? Normal dry weight is around 475 lbs.
