Arizona bike regulations
  • Bareknucklemc
  • Bareknucklemc's Avatar Topic Author
31 Jan 2011 09:13
#427370
So I'm building my bobber right now and getting close to having to liscense it, I'm in Arizona does anyone know what regulations I have to follow as far as lights, exhaust, or whether or not I have to have front brakes
Bare Knuckle MC- let the blood of those who threaten this family fill the rivers of theirs and suffer their thirst.
  • steell
  • steell's Avatar
Re: Arizona bike regulations
31 Jan 2011 09:42 - 31 Jan 2011 09:54
#427390
Go right to the source, the AZ State Code, Chapter 3, Article 16
www.azleg.state.az.us/arizonarevisedstatutes.asp?title=28
2. A motorcycle, an all-terrain vehicle and every motor driven cycle when operated on a highway shall be equipped with at least one brake that may be operated by hand or foot.
www.azleg.state.az.us/FormatDocument.asp...Title=28&DocType=ARS
A. A person shall not operate or as an owner permit the operation of a motorcycle in this state that is not equipped with the manufacturer's original muffler or other original noise reduction equipment or with a replacement muffler or replacement noise reduction equipment capable of reducing the noise levels below the maximum operating noise levels established by the department pursuant to section 28-955.02.
B. A person shall not use a muffler cutout, bypass or similar device on a motorcycle operated in this state.
The light question you'll have to look up. I have to run.
Last edit: 31 Jan 2011 09:54 by steell.
  • Motor Head
  • Motor Head's Avatar
31 Jan 2011 09:46
#427394
Having No front brake maybe the look your going for, and could well be legal I don't know. But that is where your stopping force is at, 80% or more, be a scary bike without a front brake. JMO.
  • Bareknucklemc
31 Jan 2011 10:39
#427415
thanks im transfering all pressure to the back and actually putting a trans am caliper on it to increase stopping power so im not worried
  • andy9802gt
  • andy9802gt's Avatar
  • If it tastes that good, eat it yourself.
31 Jan 2011 12:11
#427440
how do you transfer pressure from a totally seperate system? There is no proportioning valve like on a car, you pull the front brake you get front brakes only, same for rear, you the human are the proportioning valve on a bike you have to activate both brakes.
'78 KZ1075 LTD
stage 1 head by Larry Cavanaugh
race built crank by John Pearson
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
proving once again that age and treachery is better than youth and enthusiasm
  • Motor Head
31 Jan 2011 12:25
#427444
Weight transfer from the rear to front occurs when slowing/ braking, that is why rear bakes loose effectiveness.
If you have anything with a front and rear brake set up where you can have control, Motorcycle, bicycle, or whatever, try it for yourself. Get to say 30 MPH and hit both brakes, then do it again with just the front, then yet again with just the rear, all the time keeping track of the stopping distance. Rear brake only will be quite dangerous at 30MPH let alone 60+. The other bike you had posted still has the front, good to see.
  • Bareknucklemc
31 Jan 2011 15:26
#427480
I'm changing out the master cylinder to meet the caliper requirements
  • PLUMMEN
  • PLUMMEN's Avatar
31 Jan 2011 23:42 - 01 Feb 2011 02:11
#427581
pm omr B)
Last edit: 01 Feb 2011 02:11 by PLUMMEN.
  • Old Man Rock
  • Old Man Rock's Avatar
01 Feb 2011 02:22
#427589
@ Bareknuck...
PM me if you want to hook up... I'm in Glendale.
For yearly emissions, they do an idle and an idle to ramp up to 1500rpms while in neutral for 10-15 seconds... That's all there is to it....
Tweak your pilots/slow jets a 1/4 turn lean and she'll fly right through if everything else is dialed in such as no manifold leaks, carbs are sync'd, correct jetting etc....
On Road Requirements for motorcycles
* Helmet - Needed by law for under 18 years rider.
* Eye Protection - Needed if not equipped with windscreen.
* Headlight use during daytime - Headlight modulation is permitted.
* Seat for passenger - Needed if there is a passenger.
* Footrest for passenger - Needed if there is a passenger.
* Age restriction for passenger - No restriction.
* Speakers for helmet - Not restricted.
* Periodical (annual) emissions in some areas.
* Use Left mirror/Right mirror - One of it is necessary by law.
* Radar Detector - Not necessary.
* Turn Signals - Not necessary.
* Rider-Education Waiver - Test for Skill and Knowledge verification.
* Receiving motorcycle endorsement from other states - Allowed.
* State Insurance - Require compulsory liability and with the minimum limits of 15/30/10.
* Handlebar Height - 28-964C so that hands of the operator should not be above the shoulder height when the operator is sitting on seat and his hands are on the handlebar grips.
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • Old Man Rock
01 Feb 2011 02:26
#427590
This is a site covering 50 states for Motorcycle Law requirements...
As to it's degree of accuracy, how the hell would I know... :P
Splatt's Motorcycle Laws in 50 States...
www.bikernation.net/motorcyclelaws.htm
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
01 Feb 2011 15:17
#427689
Bareknucklemc wrote: "I'm changing out the master cylinder to meet the caliper requirements"
Since you have decided to ignore the relationship between momentum and the coefficient of friction I respectfully suggest you consider investing in one of these specialized meters:
  • Bareknucklemc
09 Feb 2011 05:45
#429612
anybody have any idea if AZ has the shoulder height restriction on handle bars i cant find any definitive answer
