- Thank you received: 4
Them border guards have good zip ties....
- dutchz
17 Jan 2011 20:38 #423178
by dutchz
1974 Kawasaki Z1
Stock front hub and rear axle.
Them border guards have good zip ties.... was created by dutchz
Yessir... Lost my front sprocket nut riding in the mountains along the border on Sunday and the sprocket came off the splines - not off the shaft luckily. Coulda been real bad, luckily it happed accelerating out of a corner with the bike already upright.
Looked, but the nut was long gone of course and could have fallen off miles ago. Got a zip tie from border patrol, found a piece of wood to wedge the sprocket back on the splines, made a beeline for the freeway and rode 60 miles home. I'll be safety wiring that nut from now on, thank you very much.
1974 Kawasaki Z1
- PLUMMEN
- Thank you received: 104
17 Jan 2011 22:41 #423191
by PLUMMEN
Replied by PLUMMEN on topic Them border guards have good zip ties....
- testarossa
- Thank you received: 82
18 Jan 2011 04:26 #423213
by testarossa
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
Replied by testarossa on topic Them border guards have good zip ties....
Wowee! When I saw the title to this post, I was thinking that you would be telling a slightly different story. You know the kind of story where those zip ties get used for their intended purpose. Good thing you caught that before the chain came off. So what was the tip off? Did the motor just spin up with no drive? Did anything seem unusual before you realized what was happening?
2004 ZX-10R
Angola, IN
- kz1k
- You Cant Fix Stupid!
18 Jan 2011 05:12 #423219
by kz1k
1978 KZ1000A2
Replied by kz1k on topic Them border guards have good zip ties....
crazy story. glad your ok.
1978 KZ1000A2
- T_Dub
- Thank you received: 25
18 Jan 2011 05:24 #423226
by T_Dub
1977 KZ650B1
-810cc
-Cavanaugh Racing Head
-Mikuni RS34's
-GPR Muffler
Replied by T_Dub on topic Them border guards have good zip ties....
Thats nuts Sander, glad to see no damage haha.
1977 KZ650B1
-810cc
-Mikuni RS34's
-GPR Muffler
- Thank you received: 797
18 Jan 2011 06:32 #423230
by 531blackbanshee
Replied by 531blackbanshee on topic Them border guards have good zip ties....
damnit man!
good save with the zip tie.
i love road side repairs:huh: ,i mean i don't like having to be broke down:silly: .
but i like the enginuity that comes from it.
,glad it wasn't any worse.
- Kidkawie
- I bleed premix
- Thank you received: 245
18 Jan 2011 07:26 #423245
by Kidkawie
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
Replied by Kidkawie on topic Them border guards have good zip ties....
That could have been disasterous! Nice fix!
1975 Z1 900
2004 KX125
- dutchz
18 Jan 2011 13:52 #423315
by dutchz
1974 Kawasaki Z1
Replied by dutchz on topic Them border guards have good zip ties....
Thanks fellas. What tipped me off was I gunned out of this corner and all of a sudden lost drive and revs shot up to the moon - WHOAH! Better this way than engine braking into a corner :pinch: or cranked over for that matter.
1974 Kawasaki Z1
- blipco
- 2002 KZ1000P
- Thank you received: 223
18 Jan 2011 18:19 #423398
by blipco
Replied by blipco on topic Them border guards have good zip ties....
Was there ever any Lock-Tite on it? What about the metal bend washer that holds the nut? I'm an electrician and have seen hundreds of Tie-Wraps break and none of them had to pull that duty. That one looks like a cheapy, the kind with a plastic lock inside as opposed to say a Thomas-Betts with high quality nylon and a metal lock in the head. That has to be the best balls out MacGiver I've ever seen. Glad you made it.
- dutchz
19 Jan 2011 18:08 #423656
by dutchz
1974 Kawasaki Z1
I don't remember if I put lock tite on it but it had the bent-tab washer behind it - I had to drill the locating hole for the washer in the sprocket which is a pain because of the hardening.
The zip tie was cheap but pretty thick. There is not a lot of side load on the front sprocket, and I figured the less I had to shift & shock load the transmission the better chance I had of it staying on, so babied it to the freeway asap. I made it home and it hadn't even moved a millimeter.
The sprocket has 6mm threaded holes (honda style)so I found a boogered up spare sprocket nut and safety wired it, that'll do for now.
Anyone got a clean(ish) spare sprocket nut they can part with?
1974 Kawasaki Z1
