1978 kz1000 ltd things to look for?
- fireworks
Sorry to ask a question that's probably been asked a 100 times but is there anything to be cautious about with a 1978 kz1000 ltd? I used the search but I guess I'm not very good at it!
Any typical issues? Parts expensive, is there a good supply?
It's got 65000 kms on it and it was on the road last year. Looks like basic maintenance was done to keep it road worthy but I haven't actually seen it.
What's shagged at 65K? I'm just looking for a cheap fun ride. I don't mind wrenching a bit but I don't know anything about them, I don't have much mechanical experience (but I'm not afraid to screw things up), and I have limited time. I don't want to pour money into it either. I'm good with about $500 at the beginning.
Thoughts? Thanks in advance!
- Kitten Tooth
- Thank you received: 10
1981 Kawasaki KZ1000-K LTD
1983 Suzuki GS300L-D
1982 Suzuki GS300L-Z sold:(
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
- Kitten Tooth
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
- Topper
- Thank you received: 133
Biggest thing they said to look out for was the starter clutch.
Permanent and perpetual noob.
1979 KZ750 Twin
2009 Kawasaki Versys
- Thank you received: 2229
What you need to look for are problems that one would expect on any 33 year old machine.
Check frame and suspension for signs of collision - is everything straight? Welds look solid? Cracks anywhere?
Frame rust? Look carefully around and below the battery box.
Check all electrical equipment to insure that everything works as expected. Does the starter make any odd noises? Does it engage quickly and turn the engine fast enough to start? Do all the lights work? The horn?
Does the engine make scary noises on start up? Chain, piston slap, etc? Does it smoke? Does it warm up quickly and idle smoothly?
Do the brakes feel solid (check before riding, please.)? Do the brakes work as expected when riding? Do they pulsate or make noise?
Do the forks and shocks work well? (If they are factory original shocks, they are toast.)Does everything feel tight over bumps and around curves?
If you really want to pester the seller, you can ask to see the spark plugs and do a compression test.
As noted above, check fuel tank, tires and chain & sprockets.
If the bike has been well cared for (don't be afraid to ask for maintenance records), even at 33 years and 65,000 miles, it can still be a solid bike.
Parts are generally available and are typically no more expensive than parts for other bikes.
I've no doubt overlooked a thing or two, but the sharp folks around here will fill in the blanks.
It is no accident that these old beasts are still popular.
- fireworks
I've found a 1977 standard(?) that has had Ltd wheels brakes and seat put on.
Is there any other differences between a standard and an Ltd?
- fireworks
- Thank you received: 2098
Are the J bikes the ones after 1978? I'm not that clear on when models occurred and why they are significant.
Click > www.aperaceparts.com/tech/techkz1000.html
- TeK9iNe
- What did you do!?!
- Thank you received: 28
Nice one
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
