81 KZ1100 or a 75 Z900
15 Dec 2010 19:53 - 15 Dec 2010 19:55 #417173 by davej6997
81 KZ1100 or a 75 Z900 was created by davej6997
I have a really nice 1981 KZ1100 that I have been asked to trade for a 1975 Z900.
My bike is ready to ride and doesnt take much work to keep up. The Z900 needs the valves adjusted and the carbs cleaned just to make it more of a reliable runner.It will also need a bunch of cleaning.
I am not afraid to do the work. As a matter of fact I like doing it.
From what I can tell the Z900 is more of a collector bike and is sought after more then the KZ1100.
Should I make the trade or not? Pros? Cons?
Thanks for your help on this. Just looking to get some Kawasaki lovers input.
Last edit: 15 Dec 2010 19:55 by davej6997. Reason: add pic
  • stonemaster
  • Visitor
15 Dec 2010 20:11 - 15 Dec 2010 20:14 #417174 by stonemaster
Replied by stonemaster on topic 81 KZ1100 or a 75 Z900
WTF a REAL Z!1 is much more valuable than what u have, then the ? become WHY?
I would, the value in the future is much higher for the Z1 (if it is a REAL Z1) than the 1100 JMO but if ur in doubt go to fleabay and compare auction between the two, then u will have the answer grasshopper
but again why ??? this guy offered it to u ??/ ask for booty???
Last edit: 15 Dec 2010 20:14 by stonemaster.
15 Dec 2010 21:09 #417180 by TerryK
Replied by TerryK on topic 81 KZ1100 or a 75 Z900
Hard for us to judge, but personally I'd take the 900. Never liked the looks of the 1100.
A 75 KZ900 is not a Z1 btw. Only the 73 is a true Z1.
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
15 Dec 2010 21:38 - 13 Feb 2012 19:15 #417185 by KZ250LTD
Replied by KZ250LTD on topic .
79 KZ1000ST
Past:
Many.
Last edit: 13 Feb 2012 19:15 by KZ250LTD.
  • stonemaster
  • Visitor
15 Dec 2010 22:15 #417186 by stonemaster
anal collector ??? I could but I wont
  • trianglelaguna
16 Dec 2010 03:49 #417195 by trianglelaguna
Replied by trianglelaguna on topic 81 KZ1100 or a 75 Z900
that is a nice 1100...trade for a week and see what you think then...
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
16 Dec 2010 10:47 #417231 by Mcdroid
Replied by Mcdroid on topic 81 KZ1100 or a 75 Z900
You really have to do some soul-searching on what you want in a motorcycle. If you have your 1100 dialed in and are having fun with it...keep it. If you want to own a bit of history...trade for the Z1B. :)
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
16 Dec 2010 20:15 #417337 by davej6997
Replied by davej6997 on topic 81 KZ1100 or a 75 Z900
Well it says Z1E on the motor and Z1F on the neck. He is willing to give me 800.00 with the trade. It needs carbs rebuilt, valve adjustment and gasket and general maintainence.
I like my KZ but would be interested in a bit of history and willing to do the work to clean it up.
  • trianglelaguna
17 Dec 2010 00:12 #417361 by trianglelaguna
post a pic of this Z-1????B)
1976 KZ900
2003 ZX12R
2007 FZ1000
17 Dec 2010 02:14 #417368 by Mcdroid
+1 on what trianglelaguna said...also, post the motor and frame VINs...if you are thinkng of going for the deal, make sure that the VINs 'match' and what he has: a Z1B or a KZ900...there are some value issues between the two. Be also advised, that refurbing a Z1-era bike can be a money pit and is not for the faint-hearted. You'll be trading (more or less) a perfectly good running bike for a non-runner.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
17 Dec 2010 07:52 #417396 by Kidkawie
Replied by Kidkawie on topic 81 KZ1100 or a 75 Z900
Here's my 75 Z1 build: kzrider.com/index.php?option=com_kunena&...w&catid=11&id=375078
The carb kits are cheap and you can rebuild them without disassembling the whole rack. It's not a money pit because it a Z1, I restored mine for around $1000. I didn't have to get into the engine thankfully, so most of the money was cosmetics.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
17 Dec 2010 16:14 #417476 by davej6997
Tag on frame says Z1F 53209. The motor says Z1E 053266. The title says that the Vin/Serial number is Z1FS3209.
Anyone have any idea what all this means?
Thanks for all the feadback. Really helps me learn about this bike. B)
