GPz vs Spectre vs LTD/KZ
16 Sep 2010 13:04 #399127 by apbling
GPz vs Spectre vs LTD/KZ was created by apbling
Ok, I was under the assumption that for most of the KZ bikes the standard and LTD had the same motors/cams/jetting for each bike for a given year. I was also under the assumption that the spectra was just a different paint scheme, but the GPz had hotter cams/different jetting.
Is this true? I read on another forum that they all have the same cams but then another guy chimed in and said the spectra's were a bit hotter and had more compression.
Can someone set this straight?
  • 9am53
  • homebrew, and some bbq
16 Sep 2010 13:19 #399130 by 9am53
Replied by 9am53 on topic GPz vs Spectre vs LTD/KZ
The LTD, CSR, Spectre, standard, and GPz all have the same motor essentially but the cams on the standard is usually a bit hotter than the CSR and LTD and Spectre, the GPz's cams are hotter still. The carbs are set to match the cams, the spectres have shaft drive, air suspension and 6 speeds. Later on the GPz's took on a major facelift with monoshock and some other goodies along with a different head (at least in the 1100's case) Regarding the spectres having higher compression and whatnot I don't think so, it was a cruising bike, so it had the specs of the other cruisers AFAIK. Other than cosmetic differences there are a few other mechanical things but essentially that's the most of it.
  • M357.5
  • Kwakas N' lots of em'
16 Sep 2010 13:34 - 16 Sep 2010 13:38 #399132 by M357.5
Replied by M357.5 on topic GPz vs Spectre vs LTD/KZ
Seems that they do share components with the GPz...some info on cams/head/pistons etc about half way down the page. Spectre has higher CR, GPz cams, but they didnt get the 34mm Mikunis.
www.motorcyclespecs.co.za/model/kawasaki..._Z750N%20Spectre.htm
83 KZ750L X2 + goodies = Project
84 KZ750L the mini ELR replica replica lol
84 ZX750E Turbo modded n' FAAAAASSSSSSTTTTT
85 GPz900r GREEN N' MEAN
Last edit: 16 Sep 2010 13:38 by M357.5.
16 Sep 2010 14:08 - 16 Sep 2010 14:18 #399138 by apbling
Replied by apbling on topic GPz vs Spectre vs LTD/KZ
So, the standard KZ's are hotter than the LTD's??? I thoght these were the same...
I was toying with the idea of putting GPz cams into my 82 550 LTD and 80 750 LTD, but haven't found any for a decent price. Also thinking that the rejetting required might not be to doable since some of the jets for these two model carbs don't grow on trees.
Last edit: 16 Sep 2010 14:18 by apbling.
16 Sep 2010 16:59 - 16 Sep 2010 17:16 #399164 by loudhvx
Replied by loudhvx on topic GPz vs Spectre vs LTD/KZ
On the KZ550's, the KZ550A standard had the same motor and cams as the KZ550C LTD. They are the same right down to the carbs (mechanical slide TK-22), except for the last year KZ550A, which used CV carbs.
The KZ550 D GPZ (81)had higher compression pistons, and hotter cams, reportedly better ported head, and oil cooler. The carbs were the same as the A and C (mechanical slide TK-22), but the main jets were two sizes bigger. Cosmetically, the carbs and motor were painted black.
The KZ550 H GPZ (82/83) had cosmetic changes to the motor. It is more squared off, so the valve covers are not swappable. Otherwise it is the same motor as the 81 D GPZ, with the only real change being that it had larger intake ports to accomodate the larger cv TK-26 carbs.
The ZX550 A Gpz (84-up) had even hotter cams with more duration, and the motor had different pistons to accomodate the cams. I don't know if ZX cams will drop into a KZ motor without the ZX pistons. The cam timing was 10 degrees (crank degrees) on the intake. The ZX used even larger cv TK-27 carbs. The ZX also was the first to use electronic advance on the ignition.
There is a KZ550 M which is a shaft-drive LTD. It used different cv TK carbs. I'm not sure if the motor was significantly different from the 550 C LTD other than the shaft and bigger intake ports.
The KZ550 F Spectre also used different cv TK carbs. I don't know much about the motor on the spectre.
Essentially, you can put KZ550 gpz (81-83) cams in the 550 C LTD, but without the higher compression pistons and head porting, it won't quite have the gpz power. An oil cooler would be a good idea, though. You'll need a gpz oil pan to add that.
home.comcast.net/~loudgpz/GPZweb/CamsKZZ...KZZXZR550500400.html
EDIT: the Spectre supposedly (according to Kawasaki.com) uses the same camshafts and pistons as the A standard and C LTD, so it's likely the same compression. The head does have it's own part number so maybe the head is different enough to raise compression, but I doubt it. I didn't check, but I'd bet the 550M shaft LTD would be nearly the same as the Spectre.
Last edit: 16 Sep 2010 17:16 by loudhvx.
16 Sep 2010 20:46 #399239 by Nebr_Rex
Replied by Nebr_Rex on topic GPz vs Spectre vs LTD/KZ
compression ratio, yes
cams no
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
  • M357.5
16 Sep 2010 21:05 - 16 Sep 2010 21:18 #399244 by M357.5
Blurb taken from the link....not sayin it's 100% accurate as I have no real experience, but there is reference to GPz cams being used in the Spectre. This is only pertaining to the 750, not sure about the 550 or 1100.
"There may be some gamesmanship here. The Spectre has most of the engine changes first seen on the GPz. The cylinder head has smaller combustion chambers, which raises the compression ratio to 9.5:1 from the KZ's 9:1, and the chambers have cast-in ridges that are supposed to swirl the incoming charge. The Spectre engine shares GPz camshafts. They have the same timing and lift, as the KZ models, but the cam lobes are fatter in the middle. They open the valves at a faster rate, which means the valves spend more time open, so to speak, and that gives more time and space for the mixture to come in and the exhaust to go out. The result is more torque, and better acceleration in the mid-range."
From what I've read, the 82 GPz had more aggresive cams than a KZ, faster ramps but similar overall lift ( could these be the Spectre cams in question as well ? ). The 83-85 GPz cams were more agressive yet with more lift as well. Can anyone confirm this ? Im curious as to which cams the 83/84 750L use too, I have a couple sets here.
Last edit: 16 Sep 2010 21:18 by M357.5.
17 Sep 2010 05:01 - 17 Sep 2010 05:03 #399284 by Nebr_Rex
As for the 750's.
Pistons are different between 9/1 and 9.5/1.
Spectre cams will be the same as the standard KZ.
You are referencing a British sight.
Some of thier facts are incorrect.
They also get some models (across the pond) that have different specs.
Like the GT,which is a shaft drive
and has a GPZ spec engine.
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
Last edit: 17 Sep 2010 05:03 by Nebr_Rex.
