The old KZ LIVES!!!!!!!
  • baborz72
  • Topic Author
  • Not enough hours!
05 Aug 2010 19:35 #388506 by baborz72
The old KZ LIVES!!!!!!! was created by baborz72
I had time to go back into the carbs and tank/petcock filter tonight and came home to fire the bike up.... SHE RUNS....
Sounds pretty good aside from some popping and stuff like fire from the pipe(indicating an obviously rich condition). I,m sure the valve lash needs to be adjusted( I can hear it), and the oil needs to be changed. I just wanted to be sure it was worth putting any time into it first y'know.
SOUNDS FAAAAASSSSTTTTT!!!!!
Now, Just can't wait to ride it!!!!!!!!!!!!I'll keep y'all posted.
It'll go...or...It'll blow!
05 Aug 2010 19:59 #388517 by TerryK
Replied by TerryK on topic The old KZ LIVES!!!!!!!
Good job!
Popping and flames usually indicate a LEAN condition. Most likely one or more carbs have a plugged idle circuit.
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
  • baborz72
  • Topic Author
  • Not enough hours!
06 Aug 2010 04:36 #388580 by baborz72
Replied by baborz72 on topic The old KZ LIVES!!!!!!!
Y'know...I blew them out pretty good I thought. However I didn't remove the idle circuit screws. I bet there was some crap hiding in there.;)
Because it ran and idled really good @ first. It probably picked up some of said crap. i figured that after sitting for some 10 years it probably has some sticky valves too. We've got a REALLY good professional-grade fuel system cleaner @ work I'll try. ThanksB)
