- Thank you received: 1
Small chick on a little bike
- 550A2
- keep the shiny side up
if i were you i would just use the side stand, alot less trouble..i only use my center stand when im working on my bike.
Anyway, shorter rear shocks, a little heel, and sliding your fork tubes up through your tree clamps should to lower the front should help out alot.
Good luck
-luke
82 Honda ATC 200-sold
82 Yamaha Virago 920-sold
82 Yamaha YZ250j-kept
80 Suzuki GS 550-sold
82 Kawasaki KZ550 A2-ride all the time
79 Kawasaki KZ650 C-sold
73 Kawasaki Z1 900E-paid $200, sold $6000
86 Yamaha Radian YX600-new project
- Proxy
- 80% Human 20% Nuts/Bolts
- Thank you received: 46
Take it from me cuz I found
If you leave it then somebody else is bound,
To find that treasure, that moment of pleasure,
When yours, it could have been.
1977 KZ650 B1 Being restored to original (Green)
1977 KZ650 B1 Original (Red) Sold
1977 KZ650 B1 Donor Bike for Parts
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
- muddy1
- 1980 Kz1000 LTD B4
1970 SL-70
1972 CB 750
1976 YZ 125
1976 KZ400
1979 KZ400 LTD
1980 KZ1000 LTD B4
1984 YZ 490
1989 750 Ninja
- Thank you received: 2229
www.pinkribbonrides.com/dropped.html
Ok, I should have written, "Check out how this woman picks up a large bike.", or some such.................
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- trianglelaguna
- Thank you received: 235
550A2 wrote:
ehhh, you will get use to the weight eventually. its just a balancing act. and when you do start riding it you wont find yourself pushing it all that often. "because these bikes are very reliable!"
Good luck
-luke
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
- greasechick557
- 1980 KZ750 LTD-4
- trianglelaguna
they can really drop the seat down at a upholstery shop and ask for denser foam to compensate for the loss of cushion..big time help....
some of the ltd750 owners can better tell you your stock shocks lengths...shorter shocks can be found used or ordered....the length is measured with the shock unsprung or removed(not hard to do as the other shock will keep the thing together for the moment while on it c-stand)with the shock off measure center of top hole to center of bottom hole ..ie...12 1/2 " ect...
the item i'm showing you below is designed to bolt on the bottom swingarm in the current shocks hole mounts and "lays" the shock down some by spreading the bottom shock mounts back a bit...this item in the auction pictured below is rusty but could be painted..and is gonna go cheaper...these same mounts sometimes auction for up to 50...but these rusty ones will stay lower in the bidding price imo
good luck...
1976 KZ900
2003 ZX12R
2007 FZ1000
- trianglelaguna
try going to ebay and searching these words
KAWASAKI Z1 900 KZ900 USED Rear Shock Lowering Blocks
these may not fit an ltd750 ...others will know here,,,,i have seen them on bikes and they seem to really lower the rear,but not change the bike toooo much....the handle bars are another area of change that could bring you arms and controls lower and closer to your leverage...others with 750's may help here with tips also...good luck
1976 KZ900
2003 ZX12R
2007 FZ1000
- thompsonmx100
2006 gs 500 streetfighter
1982 gpz750 breathed on wreck
1985 gpz750
Kz 650
- dejavoodo41
- Thank you received: 14
1977 KZ1000A With 1980 KZ1000A MKII engine, Wiseco 1105 kit, Dyna S Ignition, 3 Ohm Dyna Coils, Cams, Mikuni RS34 Carbs, Vance and Hines Pro Pipe with Comp Baffle
New Smyrna Beach, FL
