Machinist needed
- mjg15
14 May 2010 15:46 #367956
by mjg15
'80 Z750fx
'81 KZ550A
'81 GPz550's, Too many!
'82 KZ1000R
'82 GPz750
'90 ZR550
Project photo album: s163.photobucket.com/albums/t289/mg15_ph...GPz-ZR550%20project/
s163.photobucket.com/albums/t289/mg15_ph...current=DSC01286.jpg
Machinist needed was created by mjg15
Not sure where would be best to post this, but I'll try here. I need a few spacer rings made up to help me fit some wheel bearings for a wheel swap. I have the necessary dimensions. Aluminum would be fine. I don't have a local place so I thought I'd try here.
Thanks
Mike
mjg15@aol.com
Thanks
Mike
mjg15@aol.com
'80 Z750fx
'81 KZ550A
'82 KZ1000R
'82 GPz750
'90 ZR550
- MFolks
- Thank you received: 540
14 May 2010 15:50 #367958
by MFolks
Replied by MFolks on topic Machinist needed
Contact a member called "Black Banshee" He's a machinist that might be able to help.
If he can't help, try these people:
Custom Machine Shop Work
www.moto-lab.com
www.drf.com
www.racecase.us
www.frankmain.qpg.com/
www.mebfab.com/
www.randolphmach.com/
www.islandtechent.com/
www.moto-lab.com
www.drf.com
www.racecase.us
www.mebfab.com/
- gane
- Thank you received: 1
14 May 2010 17:47 #367979
by gane
[img][/img] 1977 KZ1000A1
Replied by gane on topic Machinist needed
Mike, Not sure this will be applicable for you, But I've done wheel swaps where different dia axles were used, & I simply cross-referenced bearings by dia,(ALA napa's bearing books) Much easier than machining carriors,& easier on my mind...luck g
- mjg15
14 May 2010 18:07 #367985
by mjg15
'80 Z750fx
'81 KZ550A
'82 KZ1000R
'82 GPz750
'90 ZR550
Replied by mjg15 on topic Machinist needed
I got a little discouraged with that because when I called All Balls Racing (they specialize in bearings)they guy that I spoke was looking in bearing books for me, but didn't see anything in conventional/common sizes. If I get spacers I can use the bearings that I have and replacing the will be easy later....but if I did find something drop-in that would be great too. I still have to get the wheels powdercoated, so I'm not in a total rush.
FWIW I need
Front 47 OD x 15 ID x 13
Rear 52 OD x 17 ID x 14
FWIW I need
'80 Z750fx
'81 KZ550A
'82 KZ1000R
'82 GPz750
'90 ZR550
- bhardy501
14 May 2010 19:01 #367999
by bhardy501
1980 KZ1000B LTD
Replied by bhardy501 on topic Machinist needed
Is that 47mmx15mmx13mmthickness and 52mmx17mmx14mmthickness. I have a lathe and could make them for you. May take me a few days to find some material. All it would cost you is the material cost and shipping. Wouldnt take long to turn them. Are they just solid round and no walls or releifs?
1980 KZ1000B LTD
