KZ550 overheating?
- dlarnold
22 Apr 2010 08:31 #362320
by dlarnold
KZ550 overheating? was created by dlarnold
Took my newly acquired KZ550 for a run yesterday and it drove well for the first hr even pushing heavy wind but last 10 mins oil light cam on and ran rough. I let it cool and rode home with the wind behind me and it ran well. Overheating perhaps? It was only 70 degress outside. Rode at around 65 - 70 mph around 6000rpm with only small hills. Any suggestions?
- JakeB
22 Apr 2010 08:45 #362325
by JakeB
1978 Z1-R
Replied by JakeB on topic KZ550 overheating?
Check to make sure you have enough oil in it. I'm not that familiar with the 550s but the oil light on the bigger bikes is for oil pressure not temp. If it's the same on the 550 then you didn't have enough oil pressure for the last part of your ride.
1978 Z1-R
- dlarnold
22 Apr 2010 17:19 #362460
by dlarnold
Replied by dlarnold on topic KZ550 overheating?
good reminder. As it was my first ride on the KZ550, I checked the oil before I rode and filled it by guestimating. When the light came on I checked the oil again and it was overfull i.e. nothing but oil in the window and had to tilt away to see the level. Could overfilling cause oil pressure problem after 1 hr of riding? Also the bike has done 37,000 miles.
Thanks
Thanks
- H1Vindicator
- Thank you received: 47
22 Apr 2010 17:57 - 20 Feb 2013 20:11 #362471
by H1Vindicator
Replied by H1Vindicator on topic ----
Last edit: 20 Feb 2013 20:11 by H1Vindicator.
- mjg15
28 Apr 2010 21:18 #364037
by mjg15
'80 Z750fx
'81 KZ550A
'81 GPz550's, Too many!
'82 KZ1000R
'82 GPz750
'90 ZR550
Project photo album: s163.photobucket.com/albums/t289/mg15_ph...GPz-ZR550%20project/
s163.photobucket.com/albums/t289/mg15_ph...current=DSC01286.jpg
Replied by mjg15 on topic KZ550 overheating?
The oil light on my 550 will come on at idle when the bike is hot and the oil apparently thins out (oil level correct). IIRc I believe that I've also had it come on one time while riding two-up and maintaining 80-85mph. My motor has less than 5000 mis.
As mentioned above , the light is a low oil pressure light, not a temp or level indicator. Check your level carefully and maybe try some high quality motorcycle specific oil if you arent currently using one.
'80 Z750fx
'81 KZ550A
'82 KZ1000R
'82 GPz750
'90 ZR550
- Motor Head
- Thank you received: 391
29 Apr 2010 05:07 #364058
by Motor Head
Replied by Motor Head on topic KZ550 overheating?
You should check your oil pressure with a mechanical gauge. Oil type and weight will change this some. You could have a pressure problem, caused by a worn oil pump, sticking bypass/ pressure valve, or to much clearance at your bearings. Best to be sure what the pressure is, then it could be as simple as a week oil light switch or a shorting to ground wire. Check it with a gauge hooked up and take it out for a ride and see it for real.
